super easy and fast question about tires
Old Dec 27, 2011 | 01:13 AM
tibasnatch's Avatar
got an 03 coupe with 18's...i know they take 245 45 18....will 245 40 18 be ok? rear of course.
see simple...thanks
Old Dec 27, 2011 | 02:19 AM
JOKER's Avatar
CLUB MODERATOR
just make sure you keep rear overall diameter larger than front and everything will be OK
Old Dec 27, 2011 | 08:43 AM
gary c's Avatar
Originally Posted by tibasnatch
got an 03 coupe with 18's...i know they take 245 45 18....will 245 40 18 be ok? rear of course. see simple...thanks
Why of course? It's actually common for members to run 245/40s front and rear when having 18" wheels. Gives you slightly better high speed control you can feel...Gary
Old Dec 27, 2011 | 09:29 AM
VQdriver's Avatar
Google search a tire diameter calculator. If the difference between the front and rear = or > 3% I would not run the tire. The VDC will be affected. If it isn't at least the stock diameter I wouldn't run it. That's just me though.
Old Dec 27, 2011 | 09:47 AM
JOKER's Avatar
CLUB MODERATOR
as long as you keep your rear larger than front, VDC don't give much crap about what size you run.
I ran several different sizes and never had any issues with VDS. As long as your front tires spin faster than rear.
Old Dec 27, 2011 | 04:07 PM
bluranver6's Avatar
What's happens if the front is bigger than the back how does it effect it ?
Old Dec 27, 2011 | 06:34 PM
nanotech's Avatar
Agreed!
nanotech's Avatar
Old Dec 27, 2011 | 07:48 PM
bluranver6's Avatar
I don't understand how will it effect the VDC and does it hurt?
Old Dec 27, 2011 | 08:15 PM
onthe3rdday's Avatar
I had to do that one night to track down a wheel vibration problem. My slip and abs lights came on at highway speeds. Based on wheel speed calculations the car will think the wheel are slipping.
Old Dec 28, 2011 | 08:09 AM
VQdriver's Avatar
What if you run a square setup? That's how I plan on running snow tires in the future. I've seen at least one post on MY350 where there was no problem with that.
Old Dec 30, 2011 | 02:21 PM
JOKER's Avatar
CLUB MODERATOR
VDC is set up to have so that your front tires spin faster than rear, If you make your rear tires smaller in diameter than front VDC will think that you are constantly spinning out of control. So as a result it will cut down a power to avoid spin out and apply brakes to stop tires from spinning (in theory)
I'm not sure about square setup. I don't think that it's going to be too much of an issue because both wheels going to spin with same speed, that is not as bad as having rear spin faster than front. Sedans come equipped with square setup from factory, and they are equipped with same VDC system, so I doubt it's going to be an issue.
Old Dec 30, 2011 | 05:53 PM
tibasnatch's Avatar
I could see a problem with changing the tire size alot but we are only talking about a 45 to a 40
Old Dec 30, 2011 | 08:16 PM
Irrelevant's Avatar
No problems here when I put my 225/55/r17 Blizzaks on all four corners.
jsimonk
Dec 22, 2023 03:49 PM
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
bjo16
Aug 4, 2015 09:52 AM
itschuckster
Jul 25, 2015 08:07 AM
