Stillen Engine Damper Installation Help
Old Jan 5, 2012 | 08:03 PM
moose0422's Avatar
Hey everyone, today I received the Stillen Engine Damper for my 2004 G coupe. I was looking at the instructions they gave me and I'm having a really tough time trying to figure out the mounting points. I've searched the forums for some pictures and there doesn't seem to be any that are of much help. If anyone would be able to give me some tips and maybe pics that would be awesome. Thanks in advance.
Old Jan 6, 2012 | 01:53 AM
Revo's Avatar
I have one installed in my 04 Coupe. I'll see if I can get pictures up tomorrow.
Old Jan 6, 2012 | 01:59 AM
05CoupeMT's Avatar
G35 Coupe 6MT
subscribed. I have the same kit laying around in my garage ever since i received it.. couldn't figure out the mounting points neither.
Old Jan 6, 2012 | 02:15 AM
Revo's Avatar
Well, Stillen did my install. They're like 10 minutes away from my house. If anyone can install it the right way, it's them. lol
Old Jan 6, 2012 | 11:12 AM
HotRodG35's Avatar
It mounts directly in front of passenger side shock tower on frame rail under power steering reservoir. You will have to loosen the power steering line bracket supporting hoses going to the power steering cooler.
I removed the power steering reservoir from mounting bracket to allow easier access.
Old Jan 8, 2012 | 04:33 PM
moose0422's Avatar
Thanks for the help guys. I think I'm just going to hold off on the install for a while. Sounds like taking the power steering reservoir out is a royal pain and I don't really have the time or the tools to install it right now anyway.
Old Mar 29, 2013 | 01:09 AM
Kerry Garrison's Avatar
Went to do the install this evening. The power steering resevoir was a piece of cake and I could see where the bottom bracket goes. I just couldn't figure out the instructions about relocating the grounding wire on the gold bracket, not sure where to relocate it to.
Old Mar 29, 2013 | 12:28 PM
Jestered's Avatar
I actually just ordered one of these, so I'd be interested in more info on the install. The install instructions don't sound very detailed, but I'm assuming it will all make sense once you pull the power steering reservoir out. I should be getting the kit this coming week and plan to do the install next weekend.
Old Mar 29, 2013 | 12:31 PM
I just need to look at it again and figure out where to relocate the grounding wire to. It says to relocate it to the bolt above where you take it off but the bracket doesn't look like it will fit there and the wire doesn't seem long enough to reach.
Old Mar 29, 2013 | 12:42 PM
Jestered's Avatar
If you're looking at the printout instructions they usually send, you probably don't have much detail in the pictures. Try looking HERE.
It's hard to tell, but it looks like Fig.1 shows the ground wire connected to the new location. If you look at the white arrow in the picture, go up above the large hose, then go to the right. It looks to me that the ground wire is connected there, which would be the new ground location. At least that's what it looks like to me.
Old Mar 29, 2013 | 12:46 PM
I just don't think that wire is going to reach up there. Maybe I need to cut some zip ties and loosen it up further back. Just tugging on it, there is no way in hell it will go up that high.
Old Mar 29, 2013 | 12:53 PM
Jestered's Avatar
Well that's interesting then. Since this is supposed to be a bolt-on and no mod kit, there must be some way of getting more slack out of that ground wire. I haven't looked under the hood at this yet, but I'm guessing it's tied up to something. Please update me/us when you get it figured out. I'm assuming I'm going to run in to the same problem, so...
Old Mar 29, 2013 | 12:58 PM
I plan on taking another stab at it this evening. The other issue is a very very small amount of space to work with. What you need is someone with REALLY small hands to get to the lower mounting points. I need to find my Mechanix gloves or go buy a new set as I can just tell my hands are going to look like ground hamburger if I try to do this without them.
Old Mar 29, 2013 | 06:03 PM
Took a good look earlier. The grounding cable is held down by a zip tie on the wheel well. It looks like popping that zip tie will provide plenty of slack. If I can get my big ogre hands and sausage fingers down into the bottom mount point than this should go smooth.
Old Mar 29, 2013 | 06:59 PM
Jestered's Avatar
I just went out and popped the hood to see if I could tell where this stuff is. I'm a little confused now. I'm not 100% sure where any of this stuff is. I know I'm in the right area, but... Also, I reread the install instructions and noticed this nugget this time:
"On frame rail (passenger side) under power steering reservoir locate two 8mm
and one 6mm bolts that secure two brackets to the frame rail and set bolts aside,
new fasteners are provided. Also at this time cut ties holding wire looms to front of
inner fender and push looms out of the way for better access.
I'm assuming they're referring to the zip tie on the wheel well that you found that's holding the ground wire. I also found that when I was looking at mine, so I at least know where that it and that it needs to be cut.
The power steering reservoir looks easy enough to get out of the way. I'm just not 100% certain where these two brackets are supposed to mount. I'm assuming I can't see the bottom bracket mount location right now because the reservoir is in the way. I'm not sure about the other one either though and I should be able to see it.
