Incorrect fuel gauge TSB?
Old Dec 30, 2004 | 08:36 PM
gte192t's Avatar
Question Incorrect fuel gauge TSB?
I have searched the forums and have some helpful threads concerning a fuel gauge problem that has struck many g35 coupe owners. Well, unfortunately it has blessed my coupe with its presence, and I want to get it fixed under warranty.
My question is what should I have myself armed with when I show up at the dealership?
Is this problem so well known that it won't be a problem getting it fixed?
This is covered under warranty, right? I have an 04 with 12k on it.
Was there really a TSB on this issue? I was unable to find it at edmunds, or in the TSB forum.
Thanks for your help!
-Chris
Old Dec 31, 2004 | 02:11 AM
Msedanman's Avatar
O.F. Administrator
No TSB that I know of, but whereever you get service, you can bet they have had some experience with this issue. It's fairly common from what I've read on our site.
Old Dec 31, 2004 | 03:46 PM
GRider35c's Avatar
i had mine changed out twice... its so common now that they stock the sending units...
you shouldnt have ANY problems at all...
Old Dec 31, 2004 | 05:26 PM
accordfreak's Avatar
so it's not the gauge itself? it's the fuel sending unit?
Old Dec 31, 2004 | 05:28 PM
Msedanman's Avatar
O.F. Administrator
That's right. It's a problem with the unit in the tank itself.
Old Dec 31, 2004 | 06:48 PM
GRider35c's Avatar
i even had my tank replaced cause it didnt fill past half... and my car is an '04.5!!
Old Dec 31, 2004 | 10:12 PM
myG35ZX's Avatar
There are actually two units in the tank. One transfers fuel from one tank to the other. Both of mine have been replaced. Works like new.
Old Dec 31, 2004 | 10:20 PM
WRAH's Avatar
WRAH
My car did this once, I force fed it, and it hasn't happened again since!
Old Dec 31, 2004 | 10:50 PM
GRider35c's Avatar
i gave it a month b4 i fixed it... jic...
Old Jan 1, 2005 | 12:25 AM
bunnone's Avatar
I've had mine in twice, works fine now.
Old Jan 9, 2005 | 08:10 PM
gte192t's Avatar
Did all of you have this replaced under warranty? Is it safe to assume that if it is covered under warranty, that all costs involved with this fix will be $0.00 out of my pocket?
Thanks,
-Chris
Old Jan 12, 2005 | 01:41 AM
j12baller's Avatar
I'm having the same problem.
Old Jan 12, 2005 | 07:28 PM
RacerX35's Avatar
Yes I had this problem and they fixed it free of charge. I even got to take an FX35 out for the day. They replaced the sending unit and the fuel pump when they fixed the problem.
Dallsinghjr1
Sep 17, 2023 11:25 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
g.spot
May 9, 2016 10:54 PM
9tray turbo
Sep 29, 2015 10:22 PM
Hogbone
Sep 28, 2015 06:44 PM
