Cant fill my gas tank
Old Feb 16, 2012 | 07:01 AM
TruGame's Avatar
I have a 05 G35 coupe i tried to full my tank 2 weeks ago and it stops half way so i tried again the next week and still fills to the half way point and stops, can any 1 help me
Old Feb 16, 2012 | 07:19 AM
oneup's Avatar
Its just the pressure thats built up, nornally it will go away after a short drive then try to fill up again
Old Feb 16, 2012 | 11:19 AM
XLR8_'s Avatar
My 04 coupe does not fill all the way up either it only goes 3/4
Old Feb 16, 2012 | 11:45 AM
TannerG's Avatar
https://g35driver.com/forums/g35-cou...stimonial.html
https://g35driver.com/forums/g-spot/...weirdness.html
Old Feb 16, 2012 | 02:10 PM
AuAltima3.5's Avatar
Flow rate for Japanese gas pumps are
Lower than the states. Try pulling the pump handle so it's halfway or 2/3 inserted in the fuel neck and use half the handle pressure
On the pump. This usually works for me.
Old Feb 16, 2012 | 02:36 PM
Mark2K8's Avatar
Mine does that. It will take in $10 worth of gas then stop even though its nearly empty... I have to put the hose in like 2/3 in and hold the trigger manually so it fills. Its a common problem, but too lazy to get it fixed.
Old Feb 17, 2012 | 01:50 AM
JeffyG's Avatar
Same problem
Mine does this sometimes, it seems to be the pumps that do this. As a test the second time this happened I had parked between the 2 pumps. When one came up short and no matter how slow I ran the fuel it would not take anymore. I then streched the other hose over and filled right up. That same pump always gives me fits.
Old Feb 17, 2012 | 02:56 AM
HeelToeSTi's Avatar
Had this at certain pumps. Not a big deal. Find a place that fills you up and keep going back.
Old Feb 17, 2012 | 10:16 AM
melikepaint's Avatar
+1
Certain stations do this to me to (04 coupe), if you have a Costco in your area, theirs work great!
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
BradMD_96
Oct 6, 2015 09:31 AM
Hogbone
Sep 28, 2015 06:44 PM
Claudiu
Sep 26, 2015 01:04 PM
