DYNO Question..
Old Jan 7, 2005 | 01:12 PM
DiamondGCoupe's Avatar
DYNO Question..
So im going to dyno my car in the morning, and getting a A/F ratio checked. Anyways i was just curious as to which gear ( 4th or 5th ) is best to dyno in? with the G thanks!
Old Jan 7, 2005 | 01:22 PM
KingOfJericho's Avatar
I've always done 4th with my other cars but they were all 5speed, I would imagine it would be the same for a 6MT since 6th is essentially an overdrive gear.
Old Jan 7, 2005 | 01:29 PM
Finiti35's Avatar
FGC South Florida BOD
I thought 5AT is dynoed in 3rd and 6MT in 4th.
Old Jan 7, 2005 | 01:36 PM
F23A4's Avatar
6MT - 5th gear and the 5AT - 4th gear. IIRC, you want to be as close to a 1:1 gear ratio as possible.
Old Jan 7, 2005 | 02:02 PM
Finiti35's Avatar
That's true, if 4th gear is your 1:1 gear, you definitely want to dyno in 4th. You can do both 3rd and 4th gear pulls, if you want the best numbers you can dyno in 3rd too. They'll be higher in 3rd gear just not as accurate.
Old Jan 7, 2005 | 02:19 PM
K thanks i get 3 pulls so i'll do one in 3rd and two in 4th thanks for the info!
Old Jan 7, 2005 | 02:52 PM
nnkfws333's Avatar
Just make sure the car is strapped down cause I've seen a car do a 4th gear pull and one of the straps broke and luckily just one. So he switched to a 3rd gear due to being scared.
Old Jan 7, 2005 | 03:38 PM
P_Diddy's Avatar
Curious, how much do dyno runs cost? I was thinking of doing a before/after when I install some mods so I can see any HP (and more importantly Torque) increase
Old Jan 7, 2005 | 06:55 PM
JohnnyCham's Avatar
i dyno'd my 6MT car twice in 4th, and once in 5th. the 5th gear dyno actually pulled 3 more horses than the 4th gear pull.
Old Jan 7, 2005 | 09:52 PM
Finiti35's Avatar
$35-40 for 3 pulls
JohnnyCham: the only reason why I said that the numbers in 3rd might look better than in 4th is based on the info in this thread. I've read about similar outcomes in other threads, but unfortunately I don't have them bookmarked. 3 more horses are an absolutely normal deviation even if you dyno in the same gear...
seagrasser
May 3, 2022 09:43 AM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
