Rear creaking
Old May 23, 2012 | 10:12 PM
mickyimp's Avatar
Rear creaking
Hi guys I have 04 g35 coupe with 26,000 miles on it and recently the rear started creaking, sounds like crumbling a plastic water bottle when its empty,I don't think it's body flexing it wouldn't be this loud if it was body flexing. It only happens on like pulling in on a drive or wavy roads at very slow speeds.
I would really appreciate help on this.
Thanks
Old May 23, 2012 | 10:56 PM
JPilla19's Avatar
While I can't tell you what it is, or why it is happening, I can share my experience with you. I was hearing the same creaking sound from the rear of my 03 coupe a few months back. It ONLY happened when I was circling the parking garage at my work. When I turned to the right and accelerated (going up the garage), it creaked pretty loudly for a few seconds then stopped when I either gained speed or straightened out the wheel. I also thought it was body flex, but it didn't creak when I cornered at higher speeds.
It's been a few months but the sound has gone away. I don't know how or why, but it's gone.
Old May 24, 2012 | 12:36 AM
sprix's Avatar
My guess is shocks. Yes, they only have 26k miles. Yes, they are also nearly 10 years old.
Old May 24, 2012 | 10:31 AM
Tiffanator's Avatar
I was hearing a similar sound from my rear driver’s wheel area, and I eventually ended up throwing two lugs and snapping the wheel studs. Granted, this could be something totally different on your car, but just something you could check and eliminate if you wanted to.
Old May 24, 2012 | 11:14 AM
DailyDrivenCoupe's Avatar
i have been chasing down a creaking noise as well. mine is only on passenger side rear and only hear the creeking/croaking sound when brakes are applied lightly. usually between 25-40% brake pressure
Old May 24, 2012 | 12:06 PM
mickyimp's Avatar
this one is pretty loud and it happens only when im making a turn at very slow speeds, and allof sudden you hear the noise like someone is crumbling a empty plastic water bottle. i used to hear a sound like this a year ago coming out of my drive way but it used to go away now it there on every turn i make at slow speeds. I'm taking it to shop on Wednesday hopefully its not body flexing because i cant live with this noise it might just be time to sell the car, hopefully something is wrong with my suspension cause im still under warranty for 4 more years.
Old May 24, 2012 | 03:19 PM
DrkBLuG35Sdn's Avatar
I have 2 rear creaks as well! 05' w/ 30K mi. One only happens sometimes and it sounds more like something is tapping on the rear windshield, but the second one is when I am making a turn my rear seams to make a creak/rattle noise but it goes away when I drive more
Old Jun 13, 2012 | 02:54 PM
kman120's Avatar
Any update on this, I have the same problem. I am pretty sure it is the compression rod and or the bushings that need to be replaced. I plan on just getting all the bushings underneath replaced as i have an 04' with 108k on it.
Old Jun 26, 2012 | 04:38 PM
mickyimp's Avatar
solved took it to the shop it was coming from the sunroof seal needed to lubricated and now the noise is gone.
rezendvous420
May 31, 2020 01:26 PM
snic09
Nov 8, 2017 01:46 PM
tiguy99
Mar 1, 2016 11:42 AM
nineiron
Sep 10, 2015 12:08 PM
iknowitsfast
Aug 12, 2015 02:08 AM
