nitrous help!!!
Old May 27, 2012 | 11:47 PM
kristinavq's Avatar
nitrous help!!!
im thinking of going with a nos wet kit !!! Im do a 35 shot because kind of scared lol What else do i need to run nitrous ?? or anything that might help??
Old May 27, 2012 | 11:56 PM
06G35Coupe94's Avatar
Plenty of other threads on this....
Old May 28, 2012 | 12:46 AM
bluedevils95's Avatar
You know, if you want to talk to the guy he might be willing to help you out w/ this. Are you local? As in cali?
Old May 28, 2012 | 02:17 AM
kristinavq's Avatar
no im not in cali .. i was just looking for some quick help because i got a shop running a special tomorrow morning 450 installed for nos kit i looked threw some thread but really no help . Also i know a guy he has a zex smart kit for 300 but i dont know if its better than the nos kit
Old May 29, 2012 | 06:48 PM
Jhambor's Avatar
These cars can supposedly take a 75 shot without any supporting mods....from what I've read. 35 shot seems weak, alot of work and money for not alot of umph. Definetly do your research. I think if anything, I'd personally go with a ZEX kit...they seem to be a fairly safe/easy setup.
Old May 29, 2012 | 07:06 PM
HotRodG35's Avatar
I have owned 5 different vehicles with NO2 and using it for 30 years
My choice is a wet shot over dry shot system.
To use NO2 safely you need the following additional equipment:
Throttle position activation switch (To ensure throttle fully open)
Window switch (prevent arming switch until sufficient load and de- activation if rev-limiter reached)
Fuel Pressure safety switch.
Nitrous Pressure Gauge.
Bottle Heater (help maintain proper bottle pressure)
All the above should be used as a minimum, to run safely above 35 HP you should Retune and add engine management system.
Engine management which will retard timing such as UTEC with remote MAP selector (switch to alternate MAP when using nitrous after Dyno Tuned)
Dyno Tune, NX Express, NOS and MSD make the above accesories needed.
For more radical setups thiers AFR lockout switches, Flow control nitrous management systems ETC.
G35VSHNG37
Sep 10, 2015 01:54 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
SoCalTed
Forced Induction
37
Oct 7, 2004 11:53 AM
jesterev
Forced Induction
12
Apr 23, 2004 10:26 PM
infidsg35
Apr 7, 2004 03:08 AM
