accelerating and just revs the rpms! please help!
Old Jun 20, 2012 | 05:31 PM
sleepy3191's Avatar
so the title pretty much sums it up, i hit the accelerator and no matter what gear im in it just revs up and then revs back down. i can barely accelerate its ridiculous, something is definitely wrong. does anyone know anything about this? thank you
Old Jun 20, 2012 | 05:48 PM
sleepy3191's Avatar
ok so i just got my car checked out and they said its my clutch, they said it needs to be replaced and that its gonna cost about 1300 dollars! they said it isnt catching it and that is for sure the clutch. does anyone have any thoughts on this? oh and by the way, i only have 48,000 miles
Old Jun 20, 2012 | 05:56 PM
Skippy's Avatar
I know in my old eclipse when the clutch was going out and would slip I would notice a very distinct odor. Sorry I know that doesn't help much but maybe someone else has more" technical" insight versus the nose test. It does seem odd for a clutch to go at 48k though.
Old Jun 20, 2012 | 06:38 PM
partyman66's Avatar
Sounds like your clutch. Do you hear any sounds, smell anything burning or feel any strange vibrations in the clutch pedal or transmission shifter when you are engaging the clutch?
Do you do a lot of stop-and-go/city type driving?
Did you have any ominous symptoms indicative of an ensuing problem over the past few weeks?.... or did the clutch all of a sudden just not work one day?
Old Jun 20, 2012 | 07:11 PM
g35sleeper123's Avatar
obviously make sure they check it out before you pay for it, but that sounds just like clutch slippage
Old Jun 20, 2012 | 11:41 PM
sleepy3191's Avatar
well no it started to get worst and worst, also yes i do feel it, it feels as if there is no way i could possibly stall out because its like there is no pressure giving back when i push the clutch. and the only time i do smell the burning is if i really start to accelerate hard and act like nothing is wrong, and yes i do alot of city driving, i live in gainesville. how much does this usually cost, also if i dont get it done at infiniti is that an issue? are they gonna put some trash clutch in or something? also is there any way of upgrading my clutch, i have an 06 coupe
Old Jun 22, 2012 | 02:54 PM
Dforez's Avatar
Well yes you can easily upgrade to a heavier duty clutch like a 6 puck or something along those lines but it will make your car far more difficult to drive and should really be reserved for cars with heavy engine modifications. The stock clutch should generally hold up for much longer than 50k miles. If you don't mind me asking, how long have you been driving standard for? It's pretty easy to destroy a clutch if the car is being driven incorrectly.
Old Jun 22, 2012 | 03:42 PM
partyman66's Avatar
Do not bring your car to Nissan or Infiniti to have them do a clutch for you. Their labor rates are significantly higher than private mechanics will charge you. More than half of the cost of a clutch replacement is usually spent on labor to install them rather than on buying the actual parts. Clutches aren't that hard of a job either if you have a lift and the right tools, so it's not like your risking screwing up your car by having it worked on by another mechanic.
If I were you, I'd order the new clutch parts yourself and bring them to a private mechanic and have him install them.
Old Jun 22, 2012 | 06:55 PM
dofu's Avatar
20 Year Member
You can easily upgrade to a heavier clutch by getting a heavier pressure plate, but you do not need a 6 puck disc.
Old Jun 22, 2012 | 10:00 PM
sleepy3191's Avatar
ok so i decided to just get my same clutch and all but the thing is i cant get it till Wednesday...so i need to know a way to save my clutch when i drive, whats the best way to drive it to prevent it from slipping or anything. i HAVE to drive 2 hours to the dealer back at home...i know its a bad idea so lets save all that talk but i have no choice, whats the best way i should be driving the car?
Old Jun 22, 2012 | 10:02 PM
dofu's Avatar
20 Year Member
You can try double clutching, but I'm not sure how well it would help since that's usually done when you need new gears. If anything, take it easy on the gas. I would just have it towed to the shop and leave it there.
06g35
Feb 14, 2022 05:59 AM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
mbe32
Nov 13, 2015 11:09 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
vamarris
Sep 26, 2015 12:56 PM
