car trouble car keeps turning off
Old Jul 28, 2012 | 03:36 AM
celtic909's Avatar
So about a month ago i got my 05 g35 a oil change at pep boys a week after the oil change my g turned off on me while driving and its getting worst it i took it to get diagnose and it read that everything was good but two days later it turnes off on me again does anyone els ever have this problem im thinking its my alternator.going bad any suggestiona?
Old Jul 28, 2012 | 10:23 AM
DBML912's Avatar
If you think the alternators going bad. Start the car and unplug the battery to see if the car keeps running.
Old Jul 28, 2012 | 04:30 PM
Mr.GEE's Avatar
20 Year Member
Check all wire connectors in the engine bay. They may have knocked a connection loose during the oil change.
Old Jul 29, 2012 | 02:24 AM
options13's Avatar
sounds like a loose wire/alternator problem.
Old Jul 29, 2012 | 04:53 AM
partyman66's Avatar
Check the connections on your battery and make sure they're both tight.
Do you have an aftermarket stereo in your car or an aftermarket alarm system?
Could you explain in more detail exactly how the car dies? Does the engine just stall, but all your electronics continue to work, or does the whole car just completely black out? Are there any symptoms prior to it turning off (bucking, loss of power, weird sounds or electrical glitches)?
Does the car start right back up after it shuts off on you?.... and is your Check Engine light on?
Old Jul 29, 2012 | 07:45 AM
Ye_Budyy's Avatar
Sometimes I have the same issue..I think...sometimes I'll be going like 40-50 then pop it into neutral cuz I'm coming up to my destination and when the rpm's drop the end up dropping so low that the car turns off...the electronics all stay on and don't flicker or anything...the car simply turns off....sometimes.
I thought I was the only one having this issue
Old Jul 29, 2012 | 12:42 PM
partyman66's Avatar
Not to sound like I'm lecturing, but this is the exact reason why you're supposed to keep the car in gear when you decelerate with a vehicle that is equipped with a manual transmission rather than putting it in neutral and coasting. If the car stalls while you're coasting to a stop in neutral, you lose your power steering and your brake-assist which could lead to loss of control of the car and a bad accident.
Old Jul 29, 2012 | 08:53 PM
UCIMAplaya2's Avatar
Like others have mentioned it could be a loose connection at the alternator or ground for the battery, engine, etc.
Random stalls can be caused by crank or camshaft position sensors but after a few times they throw a code so I doubt that is it
yours sounds like a dirty mass airflow sensor
Old Jul 30, 2012 | 12:17 AM
linedr89's Avatar
have a shop check alternator, if thats good most likely a maf or throttle problem. try a throttle re learn
Old Jul 31, 2012 | 06:23 PM
Houston Coupe's Avatar
It could be the battery post. The bolt might be loose and pop on and off. Mine did the same thing until I finally tightened it enough do it would stay on
Old Jul 31, 2012 | 07:13 PM
linedr89's Avatar
This happened to a g that came to shop today and it was crank sensor
chinee
Jun 10, 2024 07:48 PM
Hasanbaloch
Feb 29, 2024 08:45 PM
Mry
Mar 3, 2023 01:03 AM
NemesisGee
Aug 11, 2015 07:10 PM
newg37
Jul 26, 2015 09:32 AM
