Problem with ebay engine dampener
Old Sep 19, 2012 | 10:28 PM
adamj27's Avatar
Got it today, installed it 3 times because it wouldn't mount properly. It's too short (can't be extended) and the lower bracket blocks it from angling enough to align the top end even if it WAS long enough.
Bastards sent me the wrong lower hardware too that I had to get myself. I wish that was my only issue.
Should have been a ten minute install, I spend 3 hours on that. Not impressed.
Anyone else have issues with the ebay dampeners?
Old Sep 19, 2012 | 10:38 PM
herrschaft's Avatar
This is why I don't trust Ebay. Just to confirm, is that lower bracket installed with only one bolt?
Old Sep 19, 2012 | 10:40 PM
adamj27's Avatar
Everyone says how great they were, and considering its just a strut it should have been! Just a defective part that wasted too much time.
The lower bracket has 3 bolts holding it down, and one large bolt that holds the actual dampener to the bracket.
Old Sep 19, 2012 | 10:42 PM
Frankieg35's Avatar
That's eBay for ya..
Old Sep 19, 2012 | 10:46 PM
adamj27's Avatar
No kidding. My friend with an IS300 ordered his on ebay, identical part. Only difference is the mounts haha. I'm actually so pissed that it's too short, I sent the seller pictures too and he's like "I'll send you the installation manual".
Some people.
Old Sep 19, 2012 | 10:50 PM
Frankieg35's Avatar
Lmao!!
Old Sep 19, 2012 | 10:56 PM
herrschaft's Avatar
Sorry, I guess it was the upper bracket I was questioning in the first pic. A single bolt holding that small piece of metal doesn't seem very secure IMO, I foresee that bracket moving in the future.
Old Sep 19, 2012 | 10:57 PM
06G35Coupe94's Avatar
Damn Ive read nothing but great things about these too. I dont think anyone has had a problem before...
Old Sep 19, 2012 | 11:03 PM
DHCrocks's Avatar
in that first pic looks like maybe you have the bracket mounted backwards. try flipping it around then it should be closer to the damper.
Old Sep 19, 2012 | 11:08 PM
adamj27's Avatar
It's actually 2, a second bolt goes into the empty hole, through the dampener and into the engine block. It's just an unfinished shot haha.
Yeah I'm pretty pissed. As soon as I saw the wrong hardware I knew it was gonna be a hit/miss kinda part. Seller hasn't replied yet.
It's on right, it's not the fact that it's far away, its the issue that the dampener won't move closer towards the engine block. That bracket is on loose too so I could set the strut on the bottom before it was tightened. But I assure you everything is done to a T.
Old Sep 19, 2012 | 11:11 PM
herrschaft's Avatar
I'm referring to the single bolt holding the bracket itself to the engine block.
Old Sep 19, 2012 | 11:15 PM
adamj27's Avatar
I see. I don't think it'll be an issue. Well, I don't think it WOULD have been an issue haha. This seller better get back to me soon :/
Old Sep 19, 2012 | 11:44 PM
Beyond sublime's Avatar
May I ask what that does.
Old Sep 19, 2012 | 11:49 PM
herrschaft's Avatar
It keeps the engine from moving as much when under throttle, essentially it simulates a better throttle response and decreases the amount of power wasted due to the engine mounts.
Old Sep 20, 2012 | 02:18 AM
adamj27's Avatar
Back again friends. Found this.
It's length adjustable. Now if I can get it to not interfere with the bottom bracket I'll be golden.
http://www.ingallseng.com/Instructio...adjustment.pdf
