Sunroof help.
Old Oct 22, 2012 | 11:11 PM
BigOgre's Avatar
Sunroof help.
So the other day I opened my sunroof and it didn't want to close after. After closing the sunroof manually, I tried to use the button to see if it would work and it didn't. When I press the button I hear a click but nothing happens.
While doing some research I came across a few threads about a screw coming loose but they were all in regards to the v36 sedan. I'm not sure if my 05 coupe and the v36 sedans use the same motor but I don't hear anything which would indicate a loose screw.
So anyway I would just like some feedback and to know for sure if it is the sunroof motor that has gone bad.
Thanks In Advance.
Old Oct 23, 2012 | 12:17 PM
gary c's Avatar
Like every sunroof they need to be cleaned every once in a while or they'll quit working. If you can get it open clean all the rails/joints with a degreaser then carefully apply a little WD40 and check all screws. Coupes or sedans, should all have similar issues....Gary
Old Oct 23, 2012 | 12:29 PM
jutn35's Avatar
G35 Coupe
moon roofs
Old Oct 23, 2012 | 03:38 PM
BigOgre's Avatar
Would the fact that it could be dirty rails and joints, effect the ability to close the sunroof manually with no problems
Old Oct 23, 2012 | 09:23 PM
UR2klose's Avatar
it doesnt take much to jam a sunroof. if something small is in the track it will keep it from opening / closing to prevent it from breaking. at least this is what my gf's solara did when a twig was stuck in the track. it would close only half way then open back up on its own. after clean the track out it was back to working normal...
Old Oct 24, 2012 | 04:25 AM
BigOgre's Avatar
I understand that anything can jam a sunroof, but will a foreign object cause the sunroof to be effected even through it is being closed manually??
Old Oct 24, 2012 | 11:03 AM
gary c's Avatar
If there's something on the track or like you mentioned a screw sticking up....of course! Best find out what the problem is, forcing it might cause some expensive damage....Gary
Dallsinghjr1
Sep 17, 2023 11:25 AM
NailBomb
Oct 28, 2015 07:53 AM
Jcruzg35
Sep 26, 2015 04:47 PM
