View Poll Results: Which to repair first ?
Radiator, Hoses, Thermostat - $350+
28.57%
Valve covers / gaskets - $600+
42.86%
STRUTS/ Shocks- $1000+ free installation
0%
OTHER - explain / suggest
28.57%
Voters: 7. You may not vote on this poll
What to repair/replace first ?
Old Oct 28, 2012 | 07:01 PM
jutn35's Avatar
G35 Coupe
Question What to repair/replace first ?
I have a small conundrum that im trying to figure out. I was told by 2 different mechanics that if i want to do preventative maintenance on my car, i need to replace my Radiator/ hoses since the factory ones are crap. Struts and shocks should have been done at 50,000 miles so i was told by 2 other mechanics , and valve covers need replacing seeing its a problem with our G35s. I have the money to do this but which one should i do first ? My car has 82k miles on it and i am up to date with everything else so i think. Im in college so within the next month ill need to start buying parts and have this done over winter break. I like to be prepared
For My radiator im just going with the Koyorad A2258 and oem Hoses / thermostat - free installation
For Struts and Shocks im going with Tein H-Techs 350z or G35 and Bilstein HD Shocks - free installation
Valve covers are oem of course. labor = ? $.00
so please vote on which i should change out first
Old Oct 28, 2012 | 07:35 PM
AdrianVQ's Avatar
Wait, is anything actually broken? Are your hoses leaking? Installing this stuff would be like putting new tires on, when the tires you have are at 50%. I have 126k miles on my G, and I still have OEM shocks, they are still perfect. My radiator has never been changed and its perfect. And are you talking about your valve cover GASKET? Is it leaking? Why replace whats not broken?
Old Oct 28, 2012 | 07:41 PM
jutn35's Avatar
G35 Coupe
preventative maintenance, i do not want things breaking down on me when im driving to class. Valve covers are a problem for out models. Radiators on our models i have heard they start leaking around after 10 years or so, and struts and shocks i was told mine do need replacing by my mechanic friend. all of our cars are different. I wish my car could last as long as yours.
Old Oct 28, 2012 | 08:50 PM
TemjinX2's Avatar
I agree with Adrianvq...replace only if it's leaking...it should be noticeable if it is leaking...there isn't anything really to replace until you hit about 100k. It sound like those mechanics just want money. I suggest you find a different mechanic. I have 145k on my g and the radiator is still fine. No leaks from the valve covers either
Old Oct 28, 2012 | 09:04 PM
jutn35's Avatar
G35 Coupe
Well these mechanic are my freinds, known them for quite a while and said would install the Radiator and Struts for free, im paying for these parts from outside suppliers and websites, so they're getting nothing out of it and doing this on their time off using the shop tools and lifts , but the valve covers i have to go to my mechanic at infiniti
Old Oct 28, 2012 | 11:20 PM
k67p67's Avatar
With your mileage, none of those parts should be replaced as part of "preventative maintenance". If the struts are leaking or the valve cover(s) are leaking or the coolant hoses feel abnormal, then you should replace the part(s) in question. If you want to mod your G with an aftermarket radiator or lower it with some springs, that's a different story.
Old Oct 29, 2012 | 01:14 AM
G'd^'s Avatar
My G is a mile away from 100k
what maintenance would you suggest?
I was thinking spark plugs
Also, I need an O2 sensor and possibly an ABS sensor.. is O2 sensor bank 1 sensor 1 same as the rest???
Bought one from amazon and mechanic said he thinks theyre different.
My exhaust is rusted to hell. Probably going to buy a used Borla from a friend's friend. If not looking for a solid aftermarket one for a good price.. maybe around 1000
Im in college, ballin on a budget so i try to minimize price as much as possible
ANYWAY, advice on 100k tune up would be greatly appreciated..
what exactly needs to get done?
Old Oct 29, 2012 | 01:27 AM
TemjinX2's Avatar
all you really need to do at 100k is change spark plugs and wires, change transmission oil, change rear diff oil, change the air filter, change cabin filter.
maybe change the thermostat as a preventative maintaince and a coolant flush.
I would also suggest replacing 02 and abs sensors with oem sensors. some times the ecu doesn't like aftermarket sensors.
You can buy a used g35/350z exhaust for $100-200
Old Oct 29, 2012 | 01:30 AM
TemjinX2's Avatar
Nissans, hondas and toyotas are very reliable cars with low maintaince costs. My moms 03 camry shocks lasted until her car hit 260k. The car has 285k and her original oem water pump finally failed at 275k.
Old Oct 29, 2012 | 02:55 PM
VMRWheels's Avatar
Pretty much what everyone has been saying. I would just save your money for now if nothing is broken/leaking.
+1
As long as they're properly maintained they'll basically last forever!
Old Oct 29, 2012 | 03:43 PM
350GT_'s Avatar
+1 on basically what everyone else has been saying; don't fix what isn't broken. If you were gonna rebuild your motor for whatever reason then yes, it'd be good to replace all of that and more. Yes, I do realize that this would be preventative maintenance but it'd be a waste of time and money. If your plans were to upgrade those parts then that would be a different story. Don't drive around like a 16 year old and your car will last.
Old Nov 4, 2012 | 03:06 PM
jutn35's Avatar
G35 Coupe
ya you guys are right, sorry for wasting all your times "/ i get paranoid with my car.
Old Nov 4, 2012 | 06:24 PM
AuAltima3.5's Avatar
I would do whatever is in need of repair or outstanding per the OEM recommendations.
Old Nov 4, 2012 | 07:10 PM
Emerica331's Avatar
i agree with what has been said here. If the valve covers are leaking oil, i would have those replaced. I have been stranded twice due to oil leaking into/on the alternator and shorting it out.
Remington
Sep 8, 2014 05:50 PM
RA031524
Canada
42
Nov 4, 2010 12:36 PM
tiguy99
Dec 17, 2008 08:20 PM
kenempireex
Northern California
Oct 11, 2008 01:08 PM
