smoke coming out of oil cap
Old 11-15-2012, 12:54 AM
Texas-G's Avatar
so i remove the oil cap and whute smoke is coming out i checked my oil level three days ago and it was a little above full what could ut be as well it smells a little like burnt oil? my car has 30k miles i dont think it has a oc problem but i dont kbow this has me worried
Old 11-15-2012, 12:59 AM
06G35Coupe94's Avatar
What year is your car? 6mt or 5at?
Old 11-15-2012, 01:00 AM
Texas-G's Avatar
its a 2004 coupe 5at
Old 11-15-2012, 01:03 AM
Hmm. It's very possible that you can have the oc issue. Best thing to do is from now on check your oil levels more often. My friend has an 04 5at and his car has the oc issue bad.
Old 11-15-2012, 01:05 AM
Texas-G's Avatar
is that one of the signs?
Old 11-15-2012, 01:11 AM
Sorry I'm not 100% sure but if you can see smoke and smell burning oil then that's not good lol.
Old 11-15-2012, 05:49 PM
partyman66's Avatar
Could be a head gasket failure that's resulting in coolant leaking into your oil. Go for a drive, shut the car off, and then pull the oil dipstick out and see if you have a nasty milkshake looking substance on your dipstick instead of just normal-looking oil.
Also look in your coolant reservoir for oil floating in the coolant. Never open the actual radiator when the car is hot though, you can scald the $hit out of yourself.
Old 11-15-2012, 05:53 PM
Texas-G's Avatar
no not a blown head gasket already checked for that, ive dealt with that before and oil is just abit dark needs a oil change lol
Old 11-15-2012, 06:05 PM
TemjinX2's Avatar
if the oil is above the full line, i would change your oil asap. Putting in too much oil can damage your engine as much as putting in too little.
If you used synthetic oil, it burns a little lighter then convential oil which would burn more of a blue smoke. Could just be oil burning from too much oil.
I would change it and just watch the oil levels and see if you experience the same problem.
Old 11-15-2012, 06:25 PM
Texas-G's Avatar
excuse my ignorance but how would having too much damage it? and how many qts does it take i read in between 4 or 5?
Old 11-15-2012, 06:31 PM
BowWizzel's Avatar
5 quarts with filter changed
Old 11-15-2012, 07:07 PM
bocatrip's Avatar
Are you sure the smoke you see is white and not blue? White smoke is usually coolant, blue/oil. I too would suggest changing the oil and watching the oil level as well as the coolant very carefully. The coolant should be totally clean and the dipstick should not have any milky residue in it. I have not heard of any head gasket issues with our cars and the 03 and 04 automatics were not revup engines with the oil issues. If your dipstick is overfilled it should be replaced asap and go from there. Good luck.
Old 11-15-2012, 07:28 PM
Texas-G's Avatar
im pretty sure but ill double checj and whats the diff between a rev up engine and mije
Old 11-15-2012, 08:13 PM
bocatrip's Avatar
Rev up were prone to oil consumption issues 05-07 with 6speed. 03-04 weren't. I can go 6,000 miles on my 04/automatic between oil changes with the oil level still full.
Old 11-15-2012, 08:25 PM
Texas-G's Avatar
oh ok thanks for that info, and what is a "rev up" engine?
Quick Reply: smoke coming out of oil cap
