Coupe Random Little Question Thread
Rating: Thread Rating: 2 votes, 3.00 average.
Old May 9, 2015 | 09:52 AM
  #946
tha_ape's Avatar
G35 6MT Coupe
Lol what. A strut bar for our cars is for looks only. Has about as much usefulness as the ironing board out back, has for downforce lolll
Depending on the angle, an ironing board could produce quite a bit of downforce. It just wouldnt look nice, and would have a lot of drag. But lets be real here, aerodynamics on street cars (adding wings, diffusers, etc) has minimal effect. In general it is just for looks.
Old May 12, 2015 | 10:53 PM
  #947
vlascoff's Avatar
Will rear camber bolts be enough to get the wheels back in spec if I plan on getting S-techs?
Old May 12, 2015 | 10:57 PM
  #948
JKL1031's Avatar
nope nope.
Old May 19, 2015 | 03:20 PM
  #949
rowboat's Avatar
Sticky clutch and sounds
I have a 06 g35 at 70,500. For some reason my clutch started to get stuck at the half way point around 15 minutes into my drive. It just started happening, and than I also hear a scraping sounds coming from the front left wheel well when I take off in 1st.
Old May 20, 2015 | 11:45 AM
  #950
LoSt180's Avatar
Stuck meaning it won't come back up and you have to lift it with your toe? If so, then that's a common issue and the easiest fix is to bleed/flush the clutch line with new brake fluid. Takes 5-10 minutes to do, perfect if car is already in the air for an oil change.
If stuck meaning you can't press it down, then that's another problem that I don't have an answer for.
Scraping sounds can be a few things, most common are the brake dust shield rubbing on the rotor, or worn brake pads.
Old May 31, 2015 | 09:07 PM
  #951
rsingerG35's Avatar
Anyone else have the armrest bracket rubbing into the plastic?
Old Jun 15, 2015 | 11:14 AM
  #952
leo38cheng's Avatar
need a reliable shop to help fix the 2005 G35 Coupe -- lock actuator problem and replace window motor.
Thanks,
-Leo
Old Jul 9, 2015 | 05:31 PM
  #953
FoxTailWhipz's Avatar
DIY Muffler Delete Causes Loss/Gain In Power?
I recently bought a 2004 G35, and the guy I bought it from put an Infiniti Q50 exhaust on it and cut it off about 6 inches past the catalytic converter. I would like to know if this causes any gain or loss of power, if it doesn't I will just straight pipe it back and put some tips on. Any suggestions or tips for doing that would be nice also. Thanks! --Adam
Old Jul 10, 2015 | 02:02 AM
  #954
boiboii's Avatar
Help?
I'm sure this question was already asked but..what is the biggest rims and tire size I can install on my 04 G coupe without any modifications? And if anyone has any recommendations on the rims/tires size is best. Thanks
Old Jul 11, 2015 | 01:22 PM
  #955
Id say with stock suspension you could probably get by with 20" wheels, but with lowered springs, id say 19" is the max without rubbing a bunch.
Old Jul 11, 2015 | 01:24 PM
  #956
If I were you I would buy the parts and install them yourself. It would be a lot cheaper than bringing it to the shop.
Old Jul 11, 2015 | 03:22 PM
  #957
boiboii's Avatar
I was thinking 19" but what about the width and offset? What's the Max I can go without camber and rolling the fenders?
Old Jul 11, 2015 | 09:39 PM
  #958
nervseele's Avatar
couple questions for you nice gents:
the splash guards/mud guards (i think thats what they are called) are missing some of the bolts or plastic fasteners (are they metal or plastic) or whatever that hold the mud guard up and i was wondering if anyone knows what size they are and where to get some more for relatively cheap?
also, im having trouble finding a gray replacement interior piece mostly because i cant find what its technical name is, ive seen some websites call it a inner bottom door sill, ive seen it called a kick plate moulding, etc just a little confused. ive been trying to find one for a while and when i do happen across one its usually black. mine looks good but the peice that snaps it down in the back is broken so the plate just hangs there (the weatherstrip is loose because of this)
i included a picture for both questions to help clarify.
thanks!
Old Jul 12, 2015 | 01:05 AM
  #959
ScraggleRock's Avatar
thanks!
I believe they call those kinds of parts "finishers". So it'd be a lower door sill finisher.
Old Jul 12, 2015 | 02:57 AM
  #960
JKL1031's Avatar
kick plate finisher
You have already rated this thread Rating: Thread Rating: 2 votes, 3.00 average.
