**Help!! Clicking noise when turning!!**
Old Jun 4, 2013 | 09:44 PM
PLENUMCOUPE's Avatar
Exclamation **Help!! Clicking noise when turning!!**
I have an 06 g35 coupe. When I'm on big 270 degree on-ramps that have sharp turning and done at high speeds it sounds like my front axle or wheels are clicking and it does not sound good. Basically any high speed sharp turns I do. I've heard this can be ball bearings but I'm not positive and I'm afraid to get it checked out and need an expensive fix. Anyone know anything?
Old Jun 4, 2013 | 11:47 PM
rsingerG35's Avatar
There aren't front axles on a RWD car. Are you sure it isn't the rear axles? That's not uncommon and any reputable shop will check your car out at no cost.
Old Jun 5, 2013 | 12:23 AM
ItsA..Gthing's Avatar
Cv boots and axle is bad...
Old Jun 5, 2013 | 03:04 PM
Todd404's Avatar
I would say your CV joints are starting to go
Old Jun 7, 2013 | 10:44 AM
LoSt180's Avatar
I've heard that noise on a 350Z while autocrossing before. Fix is simple. Re-torque your lugnuts to the recommended 80-85 ft-lbs with a torque wrench. The clicking is because the wheels are either over or under torqued. Tire shops are notorious for over-torquing.
Old Jun 7, 2013 | 10:46 AM
I doubt that^^^
Old Jun 7, 2013 | 10:52 AM
LoSt180's Avatar
Originally Posted by ItsA..Gthing
I doubt that^^^
Considering the noise was gone after simply re-torquing the lugnuts, I'd say it's a simple fix the OP should try before spending money trying to replace CV joints that don't exist on a RWD car.
Old Jun 7, 2013 | 11:18 AM
Well O.P needs to get it checked out for sure...Then we can stop guessing..LOL
magnetism80
Feb 1, 2019 10:00 AM
mattdg35
Sep 14, 2015 11:28 AM
NJ6MT
Sep 10, 2015 08:40 AM
3000vr4tt
Sep 7, 2015 12:48 AM
pasjr1972
Sep 1, 2015 10:17 PM
