6th Gear for 5AT?
Old Jan 31, 2005 | 10:37 PM
wh1texpawn's Avatar
Question 6th Gear for 5AT?
I was looking through Performance Nissan one day and I found this: http://www.performancenissanparts.co...oducts_id=1962
So if I were to install this for my G, if I use the Manumatic mode, would I be able to "shift" into 6th gear?
Old Jan 31, 2005 | 10:41 PM
skeleton_cru's Avatar
Sedan
I'm no expert but I don't think that adds a 6th gear. It just changes the gear ratio and allows for higher RPM's before gear shifts.
Old Feb 1, 2005 | 12:26 AM
Gee Im Fast's Avatar
Yea, the only way to add a 6th gear is to get down and dirty with the gear box, almost not worth the work on an auto.
Old Feb 1, 2005 | 10:46 PM
DTrejo's Avatar
I heard the installation for that item is pretty expensive. About $800 just for labor!
Old Feb 1, 2005 | 10:49 PM
KAHBOOM's Avatar
You are probrably better off adding a Y Pipe and getting the additional acceleration through it. Less cost and risk to your warranty and you get to keep your top end performance.
Old Feb 1, 2005 | 11:43 PM
DTrejo's Avatar
What do you mean by adding a y pipe? I haven't heard of that mod yet. Are you talking about the exhaust?
Old Feb 2, 2005 | 12:03 AM
KAHBOOM's Avatar
Yep its part of the exhaust. Unlimited Tuning makes a good one from what I here. That's the route I think that I am going next. It adds a few more ponies throughout the RPM rang according to dynos. Unlimited Tuning claims 9 to 12 (I'm not sure if they are referring to this at the crank or at the wheels) But people have reviewed it and said that they have noticed a little more pickup down low.
Old Feb 2, 2005 | 12:08 AM
DTrejo's Avatar
Is a y pipe a downpipe? If so, that could probably make the car extremely loud. Especially if you have an after market exhaust.
Old Feb 2, 2005 | 01:25 AM
new35's Avatar
gear change will affect your gas mileage..... not a lot... but you will notice it!!
Rb
Old Feb 2, 2005 | 02:59 AM
Msedanman's Avatar
O.F. Administrator
That's a new ring and pinion for the rearend. It mathematically changes all the 5MT transmission gearing to a higher number for improved accelleration/ lower top speed.
With the higher rpm's in each gear, it would have a negative affect on gas mileage, and would have a negative affect on warranty too....lol.
Altho a very good mod for performance, you're better of leaving it alone.
Thebaws11
Jul 2, 2021 11:36 AM
Since 1983
Sep 19, 2015 10:26 AM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
Gwhut?
Drivetrain
Sep 6, 2015 10:07 AM
TrillO.G.35
Sep 5, 2015 02:06 AM
