Grinding noise on cold start up from engine ?
Old Jun 21, 2013 | 12:15 AM
jutn35's Avatar
G35 Coupe
Question Grinding noise on cold start up from engine ?
When i leave my car sit for about over 6 hours or over and crank it the next day I hear this loud crunching grinding noise coming from the engine area. the sound lasts for about a split second but can not be replicated until the car sits for a long time or over night and it only happens in park right after startup. This sound has been happening for alittle over 2 years or so. Its not the ABS, i know what sound that is,
My G35 coupe- auto
2003
88k miles
All fluids have been replaced at 60k miles, oil change is every 4500 miles with Full synthetic. car drives fine and normal but the noise bothers and worries me
UPDATE - PROBLEM RESIDES in either the CVT GEAR (sprocket with 4 bolts) or Chain guide tensioner( chain rattle)
CREDIT TO DGRANT FOR VIDEO
Old Jun 21, 2013 | 01:13 AM
Mugen_G35's Avatar
Sounds like the altinator. But it is strange that the sound goes away.
Have it checked out.
Old Jun 21, 2013 | 01:27 AM
jebus2006G35's Avatar
its the car testing ur ABS.. like a test i guess. check the manual and ull see its normal. your safe. theres many threads about this
Old Jun 21, 2013 | 03:29 AM
riceeeeeeeeee's Avatar
same when i start up my car and put it in gear go about 12 feet and it makes a quick grinding noise coming from the engine also.
Old Jun 21, 2013 | 08:17 AM
herrschaft's Avatar
Anytime you put the car in gear immediately after starting, the ABS system does a self test. Its audible from inside the car and you should feel a minor vibration in the brake pedal that only lasts a second.
Old Jun 21, 2013 | 12:05 PM
Kyle Barbaro's Avatar
abs self test, sounds like your cars fartin
Old Jun 21, 2013 | 01:04 PM
JKL1031's Avatar
Ah I thought it was my trans!! I had narrowed it down to do with something coming out of reverse, which I guess is most of the time I parked. Good to read this.
Old Jun 22, 2013 | 04:43 AM
jutn35's Avatar
G35 Coupe
no its not the ABS self check i now what sound that is, this sound happens right after i crank the engine and still in park. the ABS i describe as a fart noise sort of but this is like a grinding metal noise.
Old Jun 22, 2013 | 02:02 PM
totemg35's Avatar
and you said it's been doing it for 2 years now? if it was "a grinding metal noise", you would have had some sort of bad thing happen by now.
it's the ABS.
Old Jun 22, 2013 | 05:17 PM
Darkstar752's Avatar
It's your VTC gear. I'm 100% sure. That's the diagnosis, car must be cold soaked to replicate the sound, grinding noise for a second or less upon start.
Old Jun 22, 2013 | 06:19 PM
alxn91's Avatar
I have the same grinding noise on cold start, and it is not the ABS I am very familiar with that sound. Maybe somebody can help us figure out what the noise is.
Old Jun 22, 2013 | 08:34 PM
JKL1031's Avatar
Manual or automatic? Manual here.
Old Jun 23, 2013 | 12:02 AM
See the answer above your post.
Old Jun 23, 2013 | 12:40 AM
Knightstiq's Avatar
I think I have heard a noise as well, but I have always thought it was the A/C compressor. Have you noticed if the A/C is on when cold starting?
Old Jun 23, 2013 | 01:35 PM
jutn35's Avatar
G35 Coupe
VTC gear ? please explain more, And again its not the ABS.ABS happens after i start driving like a couple feet and i hear that depressing fart noise. This noise happens right after startup maybe like 2 secs tops.
