so I hydroplaned today and crashed into a curb pretty hard
Old Jul 20, 2013 | 08:50 PM
SpoonX7's Avatar
My alignment is off now and the vdc and slip light are on consistently
Are they on because of the alignment issue or because I messed up something else?
Old Jul 20, 2013 | 08:51 PM
ItsA..Gthing's Avatar
Probably your sensors got knocked out of wack...
Old Jul 20, 2013 | 09:27 PM
Frankieg35's Avatar
Sounds like an abs sensor got fukked..
Old Jul 20, 2013 | 11:49 PM
SpoonX7's Avatar
So if I fix the allignment you guys think it will fix the VDC issue?
Old Jul 21, 2013 | 12:25 AM
bchalks's Avatar
Try getting an alignment and resetting the ECU. If that doesnt work then take a closer look at the wheel well and see if you can see anything strange like a wire hanging out of place
Old Jul 21, 2013 | 01:58 AM
Blue Dream's Avatar
I drove ttrank's car solo
If you truly crashed into a curb hard, you might have significant damage to your suspension related to that wheel. If it was a front wheel you could have a bent tie rod, fvkced up compression rod or lower control arm, damage to your wheel bearing, damage to the ABS sensor as mentioned above, damage to your brake set-up, or damage to your steering knuckle among other things. You need to get your car to a trusty mechanic pronto for them to check out the whole suspension/brake set up on said wheel. Some of the things I mentioned are safety hazards if not corrected soon and no matter what the issue is you will need an alignment. Sorry to be the harbinger of doom as it may be none of those things but you need to find out what the issue is before you drive many more miles.
GL and let us know what you find out.
Old Jul 21, 2013 | 03:24 AM
SpoonX7's Avatar
When driving the only issue I felt was the alignment but none the less I am taking her to a mechanic on Monday to get checked out.
I am praying it is just the alignment because money is pretty tight , I'll let you guys know how it goes.
Old Jul 21, 2013 | 09:05 PM
DragonBoas's Avatar
Hopefully it is but I'd be willing to guess a sensor got knocked and or a busted tie rod. A buddy of mine gave a curb a love tap and it broke a cv shaft and the rear axle but that's an acura for you lol
Kng0fHrts
Sep 15, 2015 05:40 PM
mcneil_g35
Aug 5, 2015 12:03 PM
Jussaku
Aug 4, 2015 12:45 PM
Albanian122
NorthEast
Aug 3, 2015 10:47 AM
