1 inch crack in the dash
Old Sep 4, 2013 | 09:32 PM
LongJohn6284's Avatar
Just noticed this today during a cleaning, but there is about a 1 inch crack...barely separated, but still there...is there any way to stop this from going any further? probably cant fix the crack thats already there, but if theres any way to prevent it any more, i could appreciate the help...
thanks guys
Old Sep 4, 2013 | 11:49 PM
digital sol's Avatar
Got a pic? Can you get to the inside of it? If so id use plastic weld on the inside of the crack, perhaps take the edge of an old cc and do a very thin line on the outside of it as well...but typically using that on the inside of the crack will help quite a bit! Its just a small tube that after about 10-15 minutes gets rock hard. I use it on plastics alot, just cover your nose cuz its pretty potent stuff....probably not healthy to be breathing in alot
Old Sep 5, 2013 | 04:55 AM
Blue Dream's Avatar
I drove ttrank's car solo
Sadly that's a common issue on our cars. I just noticed I got my first one just to the right of the steering column above the silver trim on my 05 sedan. I'm going to try digital sol's fix to see if that stops it from spreading.
Old Sep 5, 2013 | 08:54 AM
WhosUrBuddiee's Avatar
Take dash off, get a cheap plastic welder from harbor freight, weld it from the back side.
I plastic welded my front lip to my bumper on my G37, trust me it holds.
Old Sep 5, 2013 | 03:18 PM
JKL1031's Avatar
^^hmm can you do this from the front? I have a spot on the side at the door area to try this on.^^
if ur right about the plastic trim, finish it off and cut it downwards into the trim to keep it from spreading across or up, and run some blk or be fancy with felt tape all the way across the dash about 1/8 inch tall if ur lucky to not have it too far from the plastic trim. Thats my plan,, I hadnt directed my tear downwards tho yet, even tho its my own advice im scared to do it.
Its ok. I noticed mines after I brought it home too.
Old Sep 5, 2013 | 03:27 PM
Will look like crap if you do it on the front.
Old Sep 5, 2013 | 03:33 PM
Mustang5L5's Avatar
Soldering iron will do the job as well if you don't want to spring for the plastic welder. Some filler helps
Basically you just melt the crack back together. But you gotta do it from the flipside
Old Sep 5, 2013 | 10:35 PM
thanks for the response guys...not real sure im gonna be able to take the dash off...i think i will try the first method mentioned and hope it doesnt get worse for now...if i was more mechanically able i would do the dash thing, but i think i would do more harm than good
Dallsinghjr1
Sep 17, 2023 11:25 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
g.spot
May 9, 2016 10:54 PM
DRG35R
Jan 31, 2016 07:14 AM
MrIP35
Nov 8, 2015 10:47 AM
