Annoying Squeak
Old Sep 19, 2013 | 09:32 PM
Genthusiast35's Avatar
Annoying Squeak
Hey everyone. So I realized a squeaking noise whenever I drove over tiny bumps on the road. Recently I found out that when I'm alone, theres no squeak but when there is a passenger with me, it starts again. So I'm figuring that with weight, it is the passenger side suspension. Can anyone help me target the specific part that is worn? Thanks.
Old Sep 19, 2013 | 09:41 PM
Originally Posted by WhosUrBuddiee
Your gf is fat, tell her to eat a damn salad.
Lmao, my car is too low for a fat person.
Old Sep 19, 2013 | 09:59 PM
WhosUrBuddiee's Avatar
Really there is tons of things it could be. Most likely cause on G35 is compression rods. Cover everything that moves in lithium grease and pray it goes away. Several members here have spent alot of time and money chasing mystery squeaks.
Old Sep 20, 2013 | 12:43 PM
FroZt72's Avatar
I also get an annoying squeak but only when I break as I am backing out. Not sure what is causing it.
Any suggestions?
Old Sep 20, 2013 | 01:01 PM
gary c's Avatar
Noises like you're experiencing can be caused by dozens of issues. You could spray everything under your car with silicone lubricant and hope it goes away. It could also be a worn shock since you only hear it when you have a passenger. Get your G on a rack and look for worn/loose suspension parts and spray with silicone. (won't dry out like WD40)
Gary
Old Sep 21, 2013 | 09:40 PM
murphaayyy's Avatar
why not spray one piece with silicon at a time. go for a drive and see if the squeak goes away. if it doesnt spray another piece, etc. till the squeak goes away and then you know whats causing it.
Old Sep 21, 2013 | 10:27 PM
gary c's Avatar
Locating any suspension part that may be worn and causing this squeak issue s/b your first goal. If it's just a bushing that can be sprayed to stop the squeak is the easy part. To find what you're looking for requires having your G on a lift. (rack) Taking it off and putting it back on to spray each individual part would be a major PIA!
Gary
Old Sep 22, 2013 | 09:00 AM
G_zus's Avatar
Gary makes a good point and to figure out which part was making the noise would mean lift, spray a part, and test drive one by one until you get it right. That's not very realilistic. I'm experiencing a similar squeak (besides my annoying seat creak) in my G when hitting little bumps in the road. I always assumed it was coming from the cabin and not something under the car or in the suspension. I'll make a note to see if it only happens if I'm alone or anything. Sorry I couldn't help but I feel your pain.
snic09
Nov 8, 2017 01:46 PM
AJC128
Nov 1, 2015 11:55 AM
TNRocker
Sep 21, 2015 08:36 AM
AuAltima3.5
Cooling
Sep 13, 2015 10:46 AM
