G35 Check Up Help
Old Sep 21, 2013 | 11:31 AM
Void's Avatar
G35 Check Up Help
Hey guys I recently just hit 57k miles on my '03 coupe. I purchased it at around 56,400, with 1 owner who says she always maintained it and only drove it around 10k miles in the last 2-3 years. Now I am wondering what at home check up I could do to make sure every thing is running smooth and to ensure my baby lasts way past the 150k mark?
Old Sep 21, 2013 | 04:22 PM
the93owner's Avatar
Check your fluids regularly, oil changes every 3-5k miles with full synthetic 5W-30. Your next major maintenance should be done at 60k as the factory recommends a full service (replace filters, full fluid flush, brakes checks, etc.) every 30k miles. Other than that the engine should be good to go. Check your car's service manual, it should be in the same place you keep the owner's manual.
Old Sep 21, 2013 | 05:02 PM
rsingerG35's Avatar
I'd do the 60k mile maintenance and call it good. Any suspension noise?
Old Sep 22, 2013 | 12:17 PM
Void's Avatar
The car creeks and squeeks alittle over bumps sometimes; however, I think that may just be the interior. It sounds like its coming from around the rear window area.
Old Sep 22, 2013 | 12:30 PM
redonblack35's Avatar
I'd just do an oil/air filter change to be on the safe side so that way you know what you've got running in your car. Use some engine cleaner before changing out your oil and maybe even some fuel injector cleaner. This is cheap and will give you a little piece of mind.
Old Sep 22, 2013 | 01:08 PM
Void's Avatar
I am not due for an oil change for about another 800 miles or so. Would you recommend dumping some engine cleaner into the cars oil now or wait until my oil change becomes closer?
Old Sep 22, 2013 | 01:15 PM
Urbanengineer's Avatar
Wait until just before the oil change. Please, please do not use seafoam. That can ruin your engine bud because it is like water.
Old Sep 22, 2013 | 01:35 PM
Void's Avatar
What is seafoam? EDIT nevermind I googled it and its an engine cleaner, what engine cleaner would your recommend?
Old Sep 22, 2013 | 02:22 PM
None. Synthetic oils is my only recommendation.
Old Sep 22, 2013 | 03:37 PM
g35fnatic's Avatar
Do a full tune up, make sure you change your spark plugs every 60k miles.. since youre around there maybe its time to change them.
Change your drive belts as well if they look worn out, my previous owner didnt change the drive belts for 80k miles and when I replaced it, the old one had cracks all over it.
btw congrats on your new car.. 50k miles is low on a 03 coupe. i have a 03 coupe and got it at 94k miles
Old Sep 25, 2013 | 07:52 PM
D87's Avatar
D87
Hey check out this post
Good luck!
Hasanbaloch
Feb 29, 2024 08:45 PM
R350k5
Oct 1, 2015 08:41 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
ClwMike
Jul 23, 2015 12:55 PM
