Strut/tower bar help
Old Jan 8, 2014 | 03:29 PM
PLENUMCOUPE's Avatar
I want to buy a front strut / tower bar for my 06 coupe. I have (I think it's) a 1/4" plenum spacer and K&N air intake. This is the cheapest one I found on eBay for $80 -
http://ebay.com/itm/300682078556?nav=SEARCH&sbk=1
The seller said it wouldn't fit over my spacer and aftermarket intake, but they really don't stick out much higher than the oem manifold and intake.
Anyone have that bar? Or know of a cheap one that fits well over spacer and intake? Thanks guys
Old Jan 8, 2014 | 03:31 PM
infinitidude's Avatar
I have a GTSPEC bar on mine and it clears just fine and it is adjustable for the height
Old Jan 8, 2014 | 04:16 PM
bigc's Avatar
Wings Nation
looks like an NRG bar which definitely clears the spacer. the problem with that bar is that it can rub against the hood.
this is another option for you:
https://g35driver.com/forums/steerin...tower-bar.html
fits great and the seller is local to you in socal.
Old Jan 9, 2014 | 10:25 AM
gary c's Avatar
Originally Posted by bigc
looks like an NRG bar which definitely clears the spacer. the problem with that bar is that it can rub against the hood. this is another option for you:
https://g35driver.com/forums/steerin...tower-bar.html fits great and the seller is local to you in socal.
Seans strut tower bar is a great deal and it's adjustable to clear your plenum, if you don't buy it I will...and I already have one!
Gary
Old Jan 9, 2014 | 04:16 PM
saywat?'s Avatar
itll fit. its height adjustable. the sellers probably jus being save
Old Jan 9, 2014 | 05:29 PM
Yeah that's what I figured. I also have the plastic engine cover removed
Old Jan 9, 2014 | 05:30 PM
Also how is it adjustable?? I thought these were completely rigid bars once they are mounted in
Old Jan 9, 2014 | 05:32 PM
saywat?'s Avatar
I have my cover still on. its adjustable bc the hole where the bar bolts to is elongated vertically
Old Jan 9, 2014 | 05:35 PM
Is it one hole elongated or multiple mounting holes for increased clearance height?
Old Jan 9, 2014 | 05:43 PM
saywat?'s Avatar
theres only 1 bolt for each side of the bar
Old Jan 9, 2014 | 07:04 PM
bigc's Avatar
Wings Nation
One elongated hole so the bar can be slid up and down - see below:
Old Jan 12, 2014 | 11:15 AM
Originally Posted by gary c
Seans strut tower bar is a great deal and it's adjustable to clear your plenum, if you don't buy it I will...and I already have one! Gary
Buy it dude!
Old Jan 12, 2014 | 11:21 AM
Got it thanks man. This is the one I got:
http://ebay.com/itm/130596735852?nav=SEARCH&sbk=1
Is that pic u attached of an NRG or gtspec bar? Or do You think it's the same one as what I got?
Old Jan 12, 2014 | 12:45 PM
bigc's Avatar
Wings Nation
The picture I posted is of an NRG bracket, but the GT Spec brackets are similar.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
NyCrAzY
Oct 1, 2015 09:19 AM
