Low idle and almost dies when clutch is pressed.
Old Jan 16, 2014 | 02:23 AM
Tekwhat's Avatar
My 2003 G35 coupe 6mt has been acting up as of late. I've had the car two years this February.
Last year I noticed the car almost died when I came to a stop, it did die once, and only happens when I push the clutch in. Starting this month (January) it has started doing this again, but it has yet to die, it got close, the red battery light came on but recovered.
Currently when I start the car it idles at 1000-1100. After the car warms up it wants to idle at 100-0.
For example, I get into town to get breakfast at a gas station, I get back in my car and start it, it revs up to 1000 then drops to 100-0 instantly and the car shakes a bit, I have to rev the engine sometimes or it does die. I have attached a video showing it idling when it's warm. The car has always done this.
I have read a few posts and they ask whither or not the ac is on when it idles low, I have put both no ac, and ac on in the video.
When I purchased the car it had a piggy back mapping chip, it was causing misfiring so I replaced the spark plugs, coil packs and cleaned the maf. It still misfired and was sluggish to accelerate, so I removed the mapping chip. The car has ran perfect since then and I actually gained power without the mapping chip. I have a notepad the first owner of the car kept showing oil changes and most of the mods done to the car, although it doesn't have all of them listed. By looking at the engine I believe it has a plenum spacer, it has a k&n typhoon intake, and a lot of other mods not pertaining to the engine.
I am wondering if these two issues stem from the same problem.
Old Jan 16, 2014 | 12:09 PM
Frankieg35's Avatar
Did u do a throttle body reset??
Old Jan 16, 2014 | 12:14 PM
Tekwhat's Avatar
I have not. I'm not exactly sure how to go about it.
Old Jan 16, 2014 | 03:36 PM
bchalks's Avatar
Do a throttle body reset and if that doesnt help maybe clean your MAF (Mass Air Flow Sensor)
Old Jan 16, 2014 | 03:41 PM
Frankieg35's Avatar
It should be a sticky on here, search for it, its a long process.. lol
Old Jan 17, 2014 | 09:19 AM
BjkearG35's Avatar
Had similar issue and it was my MAF. Once that was changed, ran perfect.
Old Jan 27, 2014 | 07:20 AM
jsmith29's Avatar
It's normal for the car to start at 1100 rpms and go down to about 650 or so once its warmed up. That first line on the tach is 500 rpms, not 100.
It's not normal for the car to stall when the clutch is pressed in.
Old Jan 27, 2014 | 03:46 PM
Tekwhat's Avatar
Interesting, I didn't know that was 500.
Would my heat blowing cold air when I push the clutch in be tied to this at all? When I slow down and stop my heat blows cold air, but blows hot air when I start moving again.
Old Jan 28, 2014 | 07:19 PM
Mikenotmat's Avatar
@Tekwhat my 6MT car idles lowish like yours when hot i cant imagine that the clutch has anything to do with cold air blowing when stopped. mine doesnt blow as hard when stopped but when the engine starts moving it will blow harder that is just from the alternator generating more power and making everything work as it should. check your coolant level if its low it might be efecting how much flows to the heater core. just a thought not sure.
Old Apr 22, 2014 | 03:22 PM
JSilvG35's Avatar
searching for the Throttle body reset post and cant find it... someone have a link by chance plz?
Old Dec 21, 2022 | 08:38 PM
FABIANMORENO's Avatar
infiniti G35 coupe std
hello, good afternoon, I have an infiniti G35 Coupe Std 2005, I changed the engine but since I did that, the car starts normally and after about 10 minutes if I press the Clutch it turns off, the revs are unstable, and then it turns off and no longer I can turn it on because starting becomes heavy... I already changed the starter, battery, coils, spark plugs, wiring and position sensors and crank sensor and it continues the same
Old Dec 21, 2022 | 10:29 PM
Urbanengineer's Avatar
What kinds of readings is the MAF giving you?
Old Dec 21, 2022 | 11:06 PM
make P0011, P0021, P0014, P0024 when the car is cold it starts fine, the problem is as it warms up, the faults begin... the brake becomes too soft, I would even say that it loses pressure, if I press the clutch even without setting speed, it shuts off.... after about 15 0 20 minutes ..auto shuts off and if i put it in gear again it doesn't start, the gear becomes very heavy as if unloaded...
Old Dec 22, 2022 | 12:59 PM
You could have a cam/crank shaft issue too, my car would barely run when one went out.
gatorglaze
Sep 10, 2015 12:03 PM
Jnm07
Sep 5, 2015 01:16 AM
Silver tiburon
Sep 4, 2015 07:17 PM
Kicknshift
Sep 3, 2015 09:35 AM
mdzukunft
Drivetrain
Aug 25, 2015 10:28 AM
