Ignition
Old Apr 7, 2014 | 03:40 PM
pelicanofp's Avatar
Ignition
Hi Guys
I have a 04 G Coupe and I recently replaced my spark plugs with a new set of NGK Iridium's and the old ones were NGK Platinum and since the install I've lost a decent amount of power & acceleration. Any ideas what it could be?
Thanks
Old Apr 7, 2014 | 04:19 PM
Peoria35sedan's Avatar
Either you didn't get one of the coils wire back up correctly or the gaps are wrong.
Good luck
Old Apr 7, 2014 | 06:14 PM
pelicanofp's Avatar
The NGK Iridium's are pre-gapped and all coil wires are good double checked and the engine light is not on. Any other ideas? Thanks for reply
Old Apr 8, 2014 | 12:56 AM
knightro g35's Avatar
ive heard the platinum's where better. but idk for sure.
Try putting the old ones back in or some new platinum's and see what she does.
Also check the gap, I never trust pre-gapped although they are usually right.
one fall off the shelf or mishandle could mess the gap up.
Old Apr 8, 2014 | 11:00 AM
I wouldn't trust that they are correct, those plugs fit Kia's, Hyundai's, Nissan, Toyota's and Suzuki's as well as your G, they come pre-gapped at .044, Infiniti's service manual says plug gap should be .043, do yourself a favor and always set them to the factory spec. Difference between platinum and iridium isn't performance it service life, iridium's will last longer than platinum.
As far as your power issue check all the vacuum hoses and other connectors around the engine, if you have all the coils bolted up correctly and the wires are right you may have knock something else off. I don't remember if it's on the drivers or passengers side but two of those coil wires are really easy to swap, I'd double check all of those wires.
Old Apr 8, 2014 | 11:12 AM
pelicanofp's Avatar
Alright aweasome thanks for the help guys
Old Apr 8, 2014 | 03:03 PM
Urbanengineer's Avatar
Hey... Just replaced all of the same on my friends TL and he complained about mileage.
Turns out our reckless driving taught the ECU to be in spirited mode often.
Reset your ECU by disconnecting the negative battery cable and pumping the brakes for a few seconds. After, start it up and drive it like a madman!
Old Apr 9, 2014 | 11:20 AM
pelicanofp's Avatar
Disconnected the negative terminal for a few secs and pump on the brakesand opened it up , up and down the street and is running alot better with no lag at all werid lol thank you for the help guys
junon
Jan 14, 2023 09:37 PM
mike730
Jan 12, 2018 04:25 PM
mtlruss
Dec 20, 2015 01:51 PM
pasjr1972
Sep 1, 2015 10:17 PM
.cakestar
Aug 4, 2015 09:05 PM
