Headlight Ballast Part & Replacement
Old Apr 9, 2014 | 10:12 PM
Need4Camaro's Avatar
Hi I have been searching the forums and I have answers all over the place and was hoping someone could clear this up for me.
#1 My passenger side headlight randomly dies while Im driving, usually just turning the headlights off and turning them back on brings them back to life. - This issue is most likely the Ballast correct?
#2 Can the Ballast be replaced without taking the entire front bumper off? I heard its accessible from under the car with a Phillips head screw driver?
What about the Bulb?
#3 Can the Ballast be purchased NEW from anyone outside of Infiniti ? Also what kind of Bulbs does this car take?
#4 I was seeing brand new (much cheaper) aftermarket ballast and headlight bulb's for brighter or different color headlights on eBay. Can these be used as a direct replacement or do other things need to be changed?
Old May 21, 2014 | 04:15 PM
shurur's Avatar
2003 G35 Coupe
Old May 21, 2014 | 05:02 PM
shurur's Avatar
2003 G35 Coupe
ebay..$60
Old May 25, 2014 | 07:29 AM
EPIC404's Avatar
I put a ballast on Ebay last week with no reserve and free shipping...went for a measley $17
Old May 25, 2014 | 02:28 PM
bakwoods's Avatar
I too have issues with the factory ballasts. It's shoddy design from Nissan. Seriously why would you put a ballast on the underside of a headlight where all the water will seep in and fry the electronics? I ended up just getting aftermarket ballasts and plugs and re-soldered the connectors and shrink wrapped it after. I unfortunately went through 6 factory ballasts already and each one ended up getting water in it after some time.
I pulled my headlight out without going underneath and without dropping the bumper. Though my method was also out of pure desperation because I went through so many ballasts that I stopped bolting my headlight assembly to the frame. I ended up just yanking the whole thing out and keeping the top bolt in to secure it. Not the best way, but it got the job done especially how often I had to replace stuff.
nickmcc123
Lights
Oct 7, 2017 12:18 AM
bTanz
Oct 15, 2015 02:31 PM
Karl_g335x
Aug 3, 2015 03:43 PM
attarday
Jul 15, 2015 04:03 PM
