Rear differential bushings
Old Jun 20, 2014 | 07:11 AM
rsingerG35's Avatar
So I have the leaking oem rear diff bushing. Right now im torn between energy and whiteline, mainly because whiteline is double the price. I have also read about with energy you have to re-use the metal sleeve from the oem bushing but with whiteline it comes with a new one.
Any recommendations?
Old Jun 20, 2014 | 07:29 AM
Urbanengineer's Avatar
OEM works fine and is the cheapest. I would go whiteline otherwise.
Old Jun 20, 2014 | 07:32 AM
rsingerG35's Avatar
There's no oem replacement for the subframe diff bushing. Infiniti's only option is to replace the whole rear subframe.
Old Jun 22, 2014 | 02:23 AM
dukehotty's Avatar
I have the same problem but haven't done anything yet. There is another thread on here that talks about the options. From what I read the Whiteline one is the best bet but pounding out the OEM one can be a bish w/o the right tools.
Old Jun 23, 2014 | 09:21 AM
LoSt180's Avatar
Avoid the Energy Suspension rear diff bushings. Search around, the design isn't very secure, I came across a few threads where the ES rear-most bushing had actually popped out of the subframe.
Recommendation for Whiteline from me. Also have a saw-zaw handy to cut the ring around the OEM bushing.
Old Jun 25, 2014 | 09:15 PM
terrorx7's Avatar
Just get a Sawzall and cut the oem bushing out...easier than one would think. The Sawzall cut through my metal race in minutes. Whiteline diff bushing goes in without having to mess with any metal race.
Old Jul 12, 2014 | 11:41 AM
rsingerG35's Avatar
Any tips for removing the bushings on the diff ears?
Old Jul 12, 2014 | 08:32 PM
LoSt180's Avatar
After diff is removed, flip it over and use a big socket and a hammer to pop the ear bushings out. Socket just needs to be big enough to push out the metal frame part. It will make sense when you're looking at it.
Old Jul 17, 2014 | 05:41 PM
foman13's Avatar
I had the same problem and I went with the polyurethane energy suspensions, One thing I would recommend is buying the whole bushing kit. It's about $400 and was one of the best upgrades I have done on my coupe (aside from sway bars).'
With the whole kit everything is much sharper, steering input is crisper and on flat sources it corners falter. The only downside is that the ride is a bit harsher.
Old Dec 28, 2014 | 08:11 AM
murderface's Avatar
Finished diff removal and bushing removal from diff ears last night with a little help from this tip! Drivers side bushing came out with a few taps after soaking in PB blaster. Passenger side had to drill/cut but went quick.
socket size for diff ears is 36mm for poundage or if you have access to a shop press.
Thank you!
Old Dec 29, 2014 | 12:08 PM
nizzan4u2nv's Avatar
How is in cabin noise after doing poly diff bushings?
Old Dec 30, 2014 | 03:31 AM
rsingerG35's Avatar
I didn't notice anything different in terms of noise.
Old Jan 22, 2015 | 10:13 AM
georgiadriver's Avatar
I was informed by my mechanic that my 2010 G35 has a leak in the rear differential bushing. The cost to fix is a whopping $2300. Are there any safety implications if I chose not to have it fixed?
Old Jan 22, 2015 | 10:28 AM
terrorx7's Avatar
That's because they want to replace the whole subframe assembly. Buy the Poly bushing find a competent indy mechanic and get it done for a couple hundred bucks. Read this thread.
Old Jan 22, 2015 | 04:47 PM
rsingerG35's Avatar
Not really. Just not as good of ride quality. Pick up a Whiteline rear diff kit and have a shop install it for you. It will cost a fraction of that $2300.
