Help! Riding rough!
Old Sep 13, 2014 | 12:14 PM
TheLowLife's Avatar
Help! Riding rough!
Hey guys, so recently I've noticed that my car has been riding really rough. I can feel it in my shift ***, it shakes all the time now. Even in neutral, I can hold the *** and feel the immense shaking. Any idea as to what it could be?
Old Sep 15, 2014 | 12:49 PM
infinitidude's Avatar
Possibly a stuck rear caliper. Have started seeing more and more rear caliper issues here lately.
Old Sep 15, 2014 | 09:07 PM
TheLowLife's Avatar
Well the shaking isn't as bad out of gear but I can still feel a little more shake than usual. I plan on eventually getting a short throw and that could dampen some of it.
Old Sep 15, 2014 | 09:21 PM
Void's Avatar
Is it brembos that are getting stuck because I believe im having a similar issue. I also hear a chirping noise coming from my back left wheel area when driving. It only happens when the wheels are spinning and when I apply braking pressure it stops. (I have brembos btw)
Old Sep 15, 2014 | 11:49 PM
pacificharrison's Avatar
Can you be a little more descriptive?
- For instance, I know you said "riding" rough, but at what speed do you feel something is abnormal?
- You said you feel it in the shift ****, is this only when moving, at idle, or both?
- When you say "rough", is it a chattering feeling in your shift ****? Engine knock? Something holding your car back from moving??
I'm not too sure if the caliper would come into play here, because if it were you'd feel more of a brake hesitation than shift **** shaking, but that is only my best estimated guess. We need more info man. lol
Last edited by pacificharrison; Sep 15, 2014 at 11:49 PM. Reason: Grammatical Error
Old Sep 16, 2014 | 09:55 AM
Matt6336's Avatar
I had a similar problem awhile ago, it was my rear bearings that caused it
Old Sep 16, 2014 | 10:14 AM
gary c's Avatar
You need to take your G to a qualified mechanic, get it on a rack and find out what's causing what you're describing. Changing the shifter won't change what's causing the rough ride you mentioned!
Gary
Old Sep 16, 2014 | 03:42 PM
TheLowLife's Avatar
Well it feels like metal on metal from the minute I start the car, it's slightly noticeable while idle or w/ clutch pushed in but it is really bad when in gear. The car does feel sluggish when I accelerate but I figured it was because I need new plugs.
I will definitely take it to a mechanic soon.
UPDATE: The shaking is parallel to the RPMs, the higher I go, the worse it gets.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
KruZZe
Feb 27, 2023 05:04 PM
prinny
Nov 22, 2015 11:07 PM
vamarris
Sep 26, 2015 12:56 PM
doakley92
Sep 25, 2015 12:58 PM
