HELP! VDC, slip and service engine soon lights on
Old Jan 10, 2015 | 10:13 AM
DamnGina's Avatar
Cool HELP! VDC, slip and service engine soon lights on
Ive been having a big problem with my car losing power. The other day I was going through an intersection and my car lost all power-engine still running and everything on but no acceleration. Right after that my VDC, slip and service engine lights came on and they have been on since. I had the codes read and it came up with 3 different ones.
1. Throttle position sensor
2.camshaft sensor
3. manuel mode switch
Now that I know what the problems could be, I just need some advice as to where would be a good place to start. Should I just start from the top and see if replacing one at a time works or does anyone have any ideas? The camshaft sensor was replaced about 7 months ago.
Thanks for any input
Old Jan 10, 2015 | 10:36 AM
Urbanengineer's Avatar
Camshaft position sensor from what side was replaced and what side does the code read as a problem? What brand was it.
With TPS issues you could have a loose intake or have some serious crud buildup on your intake.
Old Jan 10, 2015 | 10:53 AM
DamnGina's Avatar
I replaced the Left sensor and the code said open or short circuit condition, poor electrical connection, faulty starter motor, faulty cmp sensor and engine mechanical condition. The brand of the sensor was duralast If I remember correctly.
As far as the TPS goes should I just check everything before replacing it?
Old Jan 11, 2015 | 10:14 AM
PearlPereZ's Avatar
I believe this happened to me a couple months ago...driving like normal, then check engine, Vdc and slip light come on...lost power. Pulled over turned of my car started running fine but my check engine light was on. I replaced both camshaft position sensors and it hasn't happened since. It only showed one bad sensor but I replaced both while I was at it. Try replacing that first
Old Jan 11, 2015 | 10:44 AM
Use OEM if you have issues with the Duralast. You get can them from Infiniti parts USA.
Old Jan 11, 2015 | 07:00 PM
DamnGina's Avatar
Thank you so much guys
Mry
Mar 3, 2023 01:03 AM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
igking
Jul 19, 2015 01:12 AM
