CAI Heat Shield?
Old Apr 6, 2015 | 02:54 PM
zcherub's Avatar
CAI Heat Shield?
Just had a z-tube/CAI filter installed a couple weeks ago. At the time, I hadn't heard of the need for a heat shield for the filter on these cars.
Now that it's done, I'd like to buy a heat shield for mine, but cannot find a vendor that sells JUST the shield (they all seem to be the full kit only). Does anyone know where I could source an intake heat shield ONLY that will fit a Z1 Motorsports z-tube/CAI (pic of mine attached)?
Thanks, all.
Old Apr 8, 2015 | 12:47 PM
Ejgold55's Avatar
hahaha..... i had my z-tube "installed"......hahahaha
Old Apr 8, 2015 | 01:36 PM
Patrick Bovee's Avatar
Correct me if im wrong..... but I don't think there is heat shield ? or one that will really make a difference you still lose whp....
Old Apr 8, 2015 | 11:36 PM
zcherub's Avatar
Thanks. That's exactly what I was looking for. I really appreciate that invaluable information! For a second I was worried someone might reply in a really condescending douchey way, but I'm glad you put my mind at ease. Take care, chief.
Old Apr 8, 2015 | 11:41 PM
zcherub's Avatar
Hm - thanks for the input anyway. I know the JWT intakes come with heat shields, but I was too new with the G to think to ask Z1 about that (the intake on my Z32 was under the nose between the headlights, so heat soak wasn't a concern). If anyone else can offer any advice as to whether I should just remove/replace the intake, or modify it, I'd appreciate the input! Thx.
Old Apr 9, 2015 | 03:13 AM
christopherv5's Avatar
should fit, it just goes on the side.
https://conceptzperformance.com/Cart...on.php?II=5139
Old Apr 9, 2015 | 10:23 AM
Urbanengineer's Avatar
Originally Posted by christopherv5
should fit, it just goes on the side. https://conceptzperformance.com/Cart...on.php?II=5139
Not worth the money TBH.
Old Apr 9, 2015 | 10:28 AM
zcherub's Avatar
Thanks guys. I guess I should've researched the benefits of a CAI before. It was a given that you should put one on with the Z32, but I'm seeing a lot of V35 guys stick with stock...
Leave it as-is, heat shield, our remove the new intake altogether?
Thanks!
Old Apr 9, 2015 | 10:36 AM
gary c's Avatar
A heat shield won't do you any good, you're already SOL! You bought a black metal intake that will cost you major whp the minute the outside temp reaches 80+ degrees. Had you done any research you would have discovered these words, "Heat soak!" Enjoy getting passed by a Prius at every stop sign!
Gary
Old Apr 9, 2015 | 10:47 AM
zcherub's Avatar
Gary
Reversing the process isn't exactly an engine rebuild, Gary. Do you recommend going back to the stock airbox, then?
Old Apr 9, 2015 | 10:51 AM
rramos3's Avatar
ive always been curious about heat wrapping the intake tube regardless what its made of, but maybe itll be a good idea with the metal pipe?. what about heat wrapping with the heatshield?
im just throwing ideas out here. by that time youd prlly be spending a whole lot of money lol. z tube with paper filter FTW.
Old Apr 9, 2015 | 11:12 AM
gary c's Avatar
Not a bad but you still have the exposed cone filter that no type of shield will keep from getting very warm. Buy a Z-Tube and a AMSOIL or K&N drop in filter and you'll have the best of both worlds...direct cool filtered air and a good sound from the z-tube!
Gary
Old Apr 9, 2015 | 09:25 PM
saywat?'s Avatar
make one out of ur stock airbox jus chop it up till u get a decent fit
Picture Share
Feb 4, 2018 12:41 PM
DRG35R
Jan 31, 2016 07:14 AM
BradMD_96
Oct 6, 2015 09:31 AM
hrdwirk1
Oct 2, 2015 06:34 PM
