Adjusting clutch engagement point
Old May 14, 2015 | 07:41 PM
JKL1031's Avatar
If you do this you kill both birds.it takes away the extra travel which will also fauxly change the engagement point since you are not starting from so far down.
Old May 15, 2015 | 07:43 AM
rramos3's Avatar
Originally Posted by goodtidings
Ok so just finished doing this mod for past 3 days. In short its pretty useless as it doesn't actually lower the clutch from the bottom up, just from the top down. Its the equivalent to putting your foot on the clutch at all times without your foot actually being there.
Even worse I had a hard time readjusting it to stock, it wasn't as simple as turning the bolt the other direction... I had to turn it all the way back but that wasn't enough to get it back to normal, which really confused me and caused a lot of frustration. I then realized I had to depress the clutch with my hand slightly and then turn again, a couple of times I think.
I still don't have it back 100% stock, I couldn't get it back to that point, which is why you shouldn't **** with this at all. But I believe I am at a safe level because I regained the "clicking sound" the clutch makes when depressing it to a certain point. If you lose that sound (I think that's the helper spring?) your clutching probably isn't fully disengaged. Maybe someone can clarify?
best way to tell is jacking up the rear of the car, depressing on the clutch and running through the gears noticing if the rear tires move at all. if for any reason you cant, then its mainly feel. you shouldn't feel a lot of resistance, any gear noise, or the car nudging forward at all going into gear.
as for the pedal adjustment, if you did it a turn at a time you should have noticed a huge difference (positively). I did about 2-3 turns on mine (it was so long ago I forgot the direction already) 1 turn at a time. you should mark the rod so you can keep count of them.
remember also when you adjust your pedal to check the cruise control and ignition switch. make sure the pedal is returning to hit the button. if not you can adjust the button height as well.
all this is kind of a pain in the A, but once you get it nailed to where you like it its amazing.
Old May 15, 2015 | 10:37 AM
JKL1031's Avatar
a little twist on that rod is alot on the affect.
Old May 18, 2015 | 11:17 AM
LoSt180's Avatar
Originally Posted by rramos3
ive tried to understand how adjusting the pedal would cause premature wear. if you by any chance adjust it so that the clutch is constantly lightly engaged would you not feel pressure going into first? or even the car nudge forward?
can you adjust the pedal too far in and not feel any effects of a partially engaged clutch?
maybe im thinking too much like an experienced person? am i missing something?
You're thinking like an experienced person and that is exactly what happens when people try to adjust the pedal engagement on these cars. They don't "feel normal" so the usual feedback to avoid a partially engaged clutch doesn't exist. Simply removing the helper spring is a big improvement, but if you have to remove the pedal assembly anyway, might as well slap in an RJM pedal with even more adjustment options.
jilljann1
Jul 21, 2020 08:12 AM
mattdg35
Sep 14, 2015 11:28 AM
yosip1115
Sep 9, 2015 03:30 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
Kicknshift
Sep 3, 2015 09:35 AM
