100 octane in my G???
Old Feb 19, 2005 | 11:29 PM
BremboBoy's Avatar
I live near a gas station that salls 100 octane racing fuel. I normally put 91 octane in my G coupe. Would i notice any benefits with 100 octane fuel??
Old Feb 19, 2005 | 11:58 PM
LITE SPD's Avatar
Nope, stock ECU can probably only recognize up to 93 or 94 tops. But keep putting 100 octane in your tank and you may damage O2 sensors.
Old Feb 20, 2005 | 12:03 AM
SilverII's Avatar
my car never sees anything less than 93....so far so good
Old Feb 20, 2005 | 03:15 AM
accordfreak's Avatar
100 octane will be fine on your o2 sensor.. it's only if you're running extremely rich or running leaded fuel.
__________________
My blue interior lights
https://g35driver.com/forums/lighting/39381-stage-4-done-blue-ac-compass-temp-display.html
'04 TB 6mt nav
Old Feb 20, 2005 | 03:47 AM
GR8TG35's Avatar
Ouch, that must be expensive
How much does 100 octane fuel cost these days?
I figure by todays premium fuel prices, it must be close to $5.00 a gallon.........
Old Feb 20, 2005 | 09:02 AM
carbluecoupe's Avatar
First off you will pay a fortune for the gas as regular premium is a killer.Secondly i doubt it will benefit as the car my be hard to start and of previous experience with high octane(hesitation,erratic idle,and sluggishness)just put 94 from Sunoco and youll be fine.
Old Feb 20, 2005 | 11:07 AM
WolfsterX's Avatar
Lightbulb
I would be careful going to Sunoco because they added 10% more or less of Ethanol (alcohol, now it is Enhanced Ethanol) In the manual book, it stated that it should contain in no more than 10% otherwise you'll screw your ecu or o2 sensor. So, I'll stick with Esso gas.
g35cas's Avatar
You will probably see benefits from 100 octane if you are heavily modified and running closer to detonation(knocking). 100 octane will make you run a little more rich and farther away from detonation, meaning you can stuff more air with the same amount of fuel. If you are not modified you will probably still get more horsepower, it will not damage your car, but probably not worth the price over 92 to 94 octane.
Old Feb 20, 2005 | 11:45 AM
WOLFSTERX I used Sunoco for a year and 3 months and never had a problem with their gas.10% ethanol is okay for the engine as long as it isnt over or like you said you will mess the car up.BTW whats ESSO gas??
Old Feb 20, 2005 | 11:47 AM
balto's Avatar
ESSO is the canadian brand of Exxon.
suby01
Not G35 Related
May 25, 2016 03:07 PM
g.spot
May 9, 2016 10:54 PM
the93owner
Sep 28, 2015 10:37 PM
awalle01
Sep 28, 2015 12:36 AM
bigmike
Sep 17, 2015 01:58 PM
