G35 Coupe Not Starting After Stillen Intake
Old May 24, 2015 | 02:00 PM
crl's Avatar
crl
Hey guys, I'm fairly new to this forum, but I just installed a Stillen K&N Hi-Flow Intake w/ Z-Tube yesterday. After the first initial start-up, everything was fine (The intake sounds amazing too!). But, after driving around yesterday, I noticed that the car does not want to start after the car being warm. For instance, I drove to the store today and was in there for about 10 minutes, come out and it just dies. It turns over but just loses power and shuts off. To get it started, I will turn the ignition and have to give it some gas to keep it alive. Since the installation of the intake she runs great, it's only the start up. There are no lights either.
I have tried to reset the ECU by following this video
and it seemed like it worked, as my car was starting after, but it was on the verge of shutting off.
This is the intake kit I installed yesterday: http://www.stillen.com/product/intak...-4dr-8705.html
Once again, the car starts fine when I haven't driven it for about an hour or so. I need all the help I can get!
Old May 24, 2015 | 04:57 PM
canehdian_guy's Avatar
You didn't over oil the filter did you? Could be the MAF...
Old May 24, 2015 | 05:21 PM
crl's Avatar
crl
No the filter is fine, and yeah I figured I should try and clean the MAF and hope for the best. I just want to know if others who have added mods have experienced this, I've be lurking around and some say that the car needs to learn the new modifications that have been done, so I'm hoping that's the same case with me.
Old May 24, 2015 | 07:10 PM
upallnight's Avatar
Most likely you have an intake air leak. I would go back and check all the rubber connections to make sure the rubber didn't roll over while you where trying to put it on and now there's an air leak.
If you have the app Torque you can check the short term and long term fuel trim to see if you have a lean condition.
Old May 25, 2015 | 06:41 PM
crl's Avatar
crl
I am confident there's not an air leak, I just went in and cleaned the MAF and also checked all seals, everything seems fine. I cleaned the MAF and also did another ECU reset and the problem still persists...Hoping it just needs to learn the new intake system and will fix itself..
Old May 28, 2015 | 07:39 PM
G35Outlaw's Avatar
If you unplugged the maf you need to do the relearn procedure .
Old May 28, 2015 | 10:37 PM
crl's Avatar
crl
What is the relearning procedure? Figured that's resetting the ECU if I'm not mistaken?
Old May 28, 2015 | 11:30 PM
gary c's Avatar
Unplugging the MAF won't have any effect, I've had 3 different intakes and never even did a ECU relearn. I did unplug the negative side of the battery while making the swap just like Stillens instructions recommends! Take your G to a mechanic that has the right tools, I'd bet your MAF has gone bad...Gary
Old May 29, 2015 | 12:23 AM
crl's Avatar
crl
Hmm...Well it seems like the problem is getting better, the car has been able to start every time today, it would go very low idle and almost want to shut off, but then it will sort of spark back to life. I am just gonna give it a week and see if it will "learn" the new intake, as it does seem to be improving. Thanks!
Old May 29, 2015 | 02:01 PM
rramos3's Avatar
an intake shouldnt cause any of what youre experiencing nor the car needs to "learn". signs are pointing to some kind of screw up during install. the car should have started right up with no hesitation.
theres something funky goin on there. i would do a triple check all your vacuum hoses. especially if the car was running good before it.
another thing you can do is reinstall the OEM intake and see if the problem persists. that way youll get a confirmation if theres something else going.
ghost_g35
Aug 7, 2015 10:31 AM
LuisGee
Forced Induction
13
Jul 22, 2015 09:15 PM
Cskeet
Jul 19, 2015 12:38 AM
quickspeed6
24
Jul 15, 2015 11:06 AM
