rpm at 80mph in auto coupe
Old Feb 22, 2005 | 06:57 PM
suzook's Avatar
i was just wondering at 80 mph what rpm i should be at.i am at 3k rpm.i thought my 03 sedan auto was at about 2500.is the coupe geared dif?
Old Feb 22, 2005 | 07:02 PM
R6MO's Avatar
3 x 1000rpm
Old Feb 22, 2005 | 07:25 PM
EZZ's Avatar
EZZ
Both are geared the same. I've had loaner sedans and there was no difference.
Old Feb 22, 2005 | 08:39 PM
GEE35FX's Avatar
Final Gearing
I just checked the Infiniti site for gearing specs for the coupe and sedan. The final gear ratio is as follows:
03/04/05 Automatic Coupes and Sedans .....................3.357:1 Final Gear ratio
03/04/05 6 M/T Coupes and Sedan and G35X AWD........3.538:1 Final Gear Ratio
Therefore the manual transmision cars and the G35X should rev different than the auto coupe and sedan.
In my 05 G35X at 100km/h (60mph) = 2,450 RPM, and 120km/h (72mph) = 3,000 RPM (this is with my snows on which are supposed to be the same diameter, but there probably is some error)
Old Feb 22, 2005 | 09:30 PM
GRider35c's Avatar
my 200hp 98 V6 accord automatic did 90 at 3000 rpm's...
why is it faster at the same rpm's?? i know the answer is prolly gonna be the "final gear ratio", but what does that mean in lamens terms?? and is that better or worse? gas and/ or performance...
Old Feb 23, 2005 | 09:12 AM
Q45tech's Avatar
A 32 valve V8 generates enough torque to allow an effective final gear ratio [top gear x diff gear x tire rolling load radius] of something like 2.4-2.5 at 55 mph up a slight incline AC on with full load of gasoline and passengers [within the warranty period] [engine compression at brand new spec].
A 32 valve V6 DOES NOT therefore 10-15-even 20% more rpm are required depending on vehicle weight.
A V8 can function at 2000 rpm = 60 mph in a 4300-4500-4900 pound loaded car, a lighter weight V6 will need 2300 rpm [15% is usually].
mjfenix
Aug 17, 2017 05:49 AM
Blakearold
Aug 19, 2015 10:20 AM
joedaddy1
Jul 28, 2015 02:58 PM
igking
Jul 19, 2015 01:12 AM
.cakestar
Audio/Video/Electronics
Jul 17, 2015 08:22 PM
