Engine Replacement
Old Mar 30, 2016 | 01:39 PM
Fox843's Avatar
Engine Replacement
Hello
I am about to have the engine replaced in my 03 g35 coupe due to a cracked head...
I was wondering if I would need to have any work or flushing done to the cooling system, since I had oil and coolant mixing into each other
thanks in advance
Old Mar 30, 2016 | 03:45 PM
digital sol's Avatar
Originally Posted by Fox843
Hello
thanks in advance
They should replace the coolant via flush anyways when the new motor is put in.
Note: These motors are a royal PITA to flush and get all the air out. Highly recommend they use a vacuum system to remove the air completely. Its 1000x easier and you know the air is out completely...i spent numerous hours trying to burp and bleed the system manually and until I used a vacuum type system it still had air in it...
Thatguysg35
Apr 18, 2016 03:38 PM
SofaKingAzn
Feb 15, 2016 04:27 PM
Genthusiast35
Jan 30, 2016 02:02 PM
Jorgebarrera
Jan 25, 2016 02:42 PM
Jorgebarrera
Jan 19, 2016 06:48 PM
