ECM Relay Replacement (urgent)
Old Apr 16, 2016 | 06:53 PM
2one8's Avatar
So I suspect my ECM relay went bad. Rebuilt the motor over the winter, fired her up and it idled fine, did a few restarts while checking items and now it wont start. No power to the coils at all. Checked the ECM fuse and thats fine, only other item in the way is the relay. I have done some digging and Nissan says you have to replace the entire IDPM, but I have seen some talk about guys swapping just the relay from other vehicle models. Does anyone have experience with this? I have to get this running by Thursday to make my tune date, otherwise I cant get tuned until mid July.
Old Dec 5, 2018 | 03:44 PM
AlexanderTC's Avatar
I am having the same EXACT issue, I was hoping to find some info on this, any luck??
Old Dec 5, 2018 | 04:46 PM
telcoman's Avatar
Veteran: Army
Come back in July and let us know how you made out.
The FSM has some good info in the EC section.
Use your multimeter to check all the harness connections.
Telcoman
Old Dec 5, 2018 | 07:15 PM
FreshLikeAG's Avatar
There is an ignition fuse that might be bad. Four things you need for an engine to run. Spark, fuel, air, and compression. I'd start with spark...
Old Dec 5, 2018 | 08:24 PM
Blue Dream's Avatar
I drove ttrank's car solo
Telcoman
That's a 2.5 year old thread you responded to but thanks for playing.
Old Dec 6, 2018 | 05:34 AM
telcoman's Avatar
Veteran: Army
I went back to look at the OP's post and you are correct but others responded & I never noticed the date on the OP's post.
But my point to the OP and others having the same problem is go carefully read the FSM prior to coming here to ask why their vehicle won't start with no spark.
Telcoman
Old Jun 4, 2021 | 12:52 AM
archi's Avatar
infiniti g35
Any new reader to this thread, having the same problem, may find ANY added info helpful, regardless of HOW long it was added, after the op posted, Talking
ZBigKahuna
Apr 27, 2016 07:40 PM
JRandallC
Apr 17, 2016 10:12 AM
silverG2007
Apr 16, 2016 03:32 PM
mjw011689
Apr 16, 2016 01:54 PM
iTzTeddy
Apr 13, 2016 06:18 PM
