I've got an 03 g35 coupe, 6speed, and I know I'm missing an Engine appearance cover, the battery cover and the air filter cover, but I noticed my battery moves around relatively freely in the vehicle which has caused the bolt on the terminal to get all janky and need to be replaced, so I'm wondering if just buying the battery cover is what would hold it in place, or is there also a metal piece that holds it down that I'm missing?
I can supply pictures if that helps.
Thanks!
Thanks!
cleric670
BANNED!!!
close
- Join DateMay 2017
- LocationWashington State
iTrader Positive Feedback0
iTrader Feedback Score(0)
- My RideCoupe 6MT Premium RAS
Liked:2,497 Times in 2,182 Posts
There is a tiedown for the battery that you're probably missing. In the meantime the "double hook rubber strap" has faithfully held batteries down for the better part of 50 years.
Urbanengineer
close
- Join DateJun 2013
- LocationOH-IO
iTrader Positive Feedback100
iTrader Feedback Score(3)
Liked:1,045 Times in 960 Posts
Quote:
Excellent point.Originally Posted by cleric670@gmail
I’ve found it tough to find the J bolts that hold down the mount though. Have been looking on eBay and such.
Pictures included in the link below, its for a sedan you can see what you may be missing.
https://g35driver.com/forums/g35-sed...-tie-down.html
Urbanengineer
close
- Join DateJun 2013
- LocationOH-IO
Doesn’t work... not even close. The G’s rear holder is like 2” Long at most.
I hate our factory battery tie down bracket.
I take it off at least twice a year to remove battery for maintenance and winterizing. It's a huge PITA to get the rear J- hook mounted right into the hole in the chassis and keep it there while tightening.
Urbanengineer
close
- Join DateJun 2013
- LocationOH-IO
Mine is lost in translation, zip ties have worked for almost 5 years now :/.
telcoman
close
- Join DateMar 2011
- LocationCentral NJ
- My RideFront and rear cameras, tire pressure for all four tires can display on screen,folding side view mir
Liked:197 Times in 178 Posts
As an owner of two Infiniti's over almost twelve years I've never had a need to remove a battery of either vehicle. Perhaps you can enlighten me exactly what "winterizing" a battery means?Originally Posted by partyman66
I hate our factory battery tie down bracket.I take it off at least twice a year to remove battery for maintenance and winterizing. It's a huge PITA to get the rear J- hook mounted right into the hole in the chassis and keep it there while tightening.
Aside from using a battery hydrometer to measure the specific gravity of each cell to determine if they are up to a full charge, which does not require the battery to be removed from the vehicle, I am perplexed as to why you have a need to remove your battery twice a year?
Telcoman
cleric670
BANNED!!!
close
- Join DateMay 2017
I take the batteries in all my vehicles (toro z-turn mower included) out once a year when doing a full electrical system cleaning. Might be a little OCD...
Ok, sounds like I'm gonna forego liking for the actual piece and make it work with some zip ties or something lol thanks everybody
cleric670
BANNED!!!
close
- Join DateMay 2017
You can get the whole OEM assembly for like $25 from your local nissan / Infiniti dealership or just order it from one of the online Infiniti dealers. Here's the dealer site I typically use for that stuff but you can take the part numbers down to the local dealership and just buy in-town. It's the same for most Nissan / Infiniti vehicles so it should be an in-stock item. Don't forget you need both the front and rear item #3.
https://www.infinitipartsonline.com/...t/battery-scat
EDIT: oops you have a coupe, scroll down and get part 3, 4 for the coupe stuff at the bottom.
You can get the whole OEM assembly for like $25 from your local nissan / Infiniti dealership or just order it from one of the online Infiniti dealers. Here's the dealer site I typically use for that stuff but you can take the part numbers down to the local dealership and just buy in-town. It's the same for most Nissan / Infiniti vehicles so it should be an in-stock item. Don't forget you need both the front and rear item #3.https://www.infinitipartsonline.com/...t/battery-scat
ohhhh alright fair enough I guess I could do that since you made it so easy for me haha thank you!
Telcoman
I remove the battery all together during the winter as the car sits outside under a car cover and remains undriven from the day before the first winter snow-storm (anywhere from early November until late December) until sometime in late March or early April after the snow and road salt are gone. This is one of the many precautions i take and have taken every year that I've had the car since '04 to keep it in pristine condition throughout the $hitty winter here in Massachusetts.Originally Posted by telcoman
As an owner of two Infiniti's over almost twelve years I've never had a need to remove a battery of either vehicle. Perhaps you can enlighten me exactly what "winterizing" a battery means?Aside from using a battery hydrometer to measure the specific gravity of each cell to determine if they are up to a full charge, which does not require the battery to be removed from the vehicle, I am perplexed as to why you have a need to remove your battery twice a year?
Telcoman
The car is parked outside in my driveway a solid 75 feet from the house, so I can't easily keep it wired into a trickle charger, and would also rather not have to worry about keeping another electrical appliance plugged in all the time anyways. I just throw the removed battery on a trickle charger while it's in the house once a month or so during the offseason to keep it topped up while it sits on the shelf in my basement. My Optima red-top is now about 9 or 10 years old and holding up pretty well by doing this every year. I do the same with all of my motorcycles.
Quote:
I figured it was something you were doing for rough cold weather months. Originally Posted by partyman66
I remove the battery all together during the winter as the car sits outside under a car cover and remains undriven from the day before the first winter snow-storm (anywhere from early November until late December) until sometime in late March or early April after the snow and road salt are gone. This is one of the many precautions i take and have taken every year that I've had the car since '04 to keep it in pristine condition throughout the $hitty winter here in Massachusetts..
For the OP, you could find those items at a junkyard/pull-a-part also. However, it sounds like the battery tie down assembly is pretty cheap at the dealer.
