white layer in coolant, normal?
Old Apr 16, 2018 | 08:18 PM
qazam96's Avatar
is this normal? car was last driven three weeks ago and its been sitting ever since, weather is messed up so cant drive it
98000 miles 2003 g35 coupe manual
weird white layer in coolant
Old Apr 16, 2018 | 08:24 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Kinda hard to tell from the photo, is it sediment or something, if you take a screwdriver and swish it around does it just float or immediately settle?
If it's been 30k since the last coolant flush you should probably do one and drain it into a very clean bucket so you can see if it's got a bunch of sediment in the coolant.
Old Apr 18, 2018 | 08:15 PM
partyman66's Avatar
It doesn't look that bad. My first thought upon reading this title was that you may have had oil leaking into your coolant as a result of a head gasket failure, but that's too small of a buildup to be that.
As Cleric said... you are probably just due for a coolant change.
How long have you had the car too? It's possible that this car may have had a blown head gasket in the past that resulted in some oil contamination of the coolant, and there may have been trace remnants of it left in the system after they flushed it. Oil and water don't mix, so sometimes it's hard to get it completely cleaned out without doing like 10 flushes.
gesekee19
Southern California
Apr 20, 2007 04:53 PM
nyckid
Oct 3, 2006 08:11 PM
harley01
May 13, 2005 02:27 PM
bsoo
Sep 2, 2004 07:19 PM
RamboRami
Oct 8, 2003 08:07 PM
