Ipdm Harness repair
Old Apr 18, 2018 | 09:23 PM
Afflicted's Avatar
Ipdm Harness repair
I have a 2003 350z that the wires have pulled out of the E7 connector. The ipdm is the same as in a 2003 G35. I am trying to find a diagram that will show me which color wire goes onto which pin
Old Apr 18, 2018 | 09:46 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Hopefully someone can snip out the 2003 IPDM layout from section PG of the FSM, Here's the one for the a 2006 coupe which might help? Green/Yellow is what the color is listed as AT the IPDM, That's for the ignition switch correct?
Old Apr 19, 2018 | 03:52 PM
Afflicted's Avatar
Probably. This all started from replacing the AC compressor. Short version, I was tracing the Compressor Clutch power wire through the harness looking for a physical break. In the process, all of the wires for the E7 plug have come out. I am hoping someone has a wiring diagram, or knows which wire corresponds to which pin. Apparently, had I had this problem last month, I could have accessed the FSM myself. Thanks Nissan.
eloke
Dec 19, 2016 10:40 AM
Swaglife81
Nov 5, 2016 03:24 AM
dargondev
Sep 11, 2016 11:18 AM
BillR
Jun 7, 2003 09:44 AM
