My g lost all power!!!!
Old Jul 29, 2018 | 03:17 PM
Bell Heli’s's Avatar
Hello guys is was driving my 2005 coupe and completely lost all power and still have no power replaced battery ground wire and battery because battery tested bad and afte that the positive battery terminal started arcing and still had no power any and all help will be greatly appreciated
Old Jul 29, 2018 | 05:00 PM
telcoman's Avatar
Veteran: Army
Blown fuses?
A short caused by any electrical additions/mods?
Use your multimeter to trace point to point
Having a copy of the FSM would help you
Telcoman
Old Jul 29, 2018 | 06:54 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
The positive terminal battery cable has a device called a "fusible link". If you look closely at it the battery lug is a square-ish device and the battery CABLE bolts to this device with a large stud/nut on the top of it.
Disconnect the NEGATIVE WIRE FIRST ALWAYS. FIRST wire you remove, LAST wire you install.
Then you can safely disconnect the positive side and take the fusible link off, there are clear plastic inspection windows to visibly check the internal fuses to see if they are blown.
It helps if you remove the entire battery tray cover and not just the little snap on access hole cover.
Old Aug 1, 2018 | 03:15 AM
Thanks telcoman I found the problem wire for starter melted on my test pipe
Old Aug 1, 2018 | 05:50 PM
Jimster480's Avatar
Battery Fuse?
Old Aug 1, 2018 | 06:39 PM
Blue Dream's Avatar
I drove ttrank's car solo
Please read entire threads before you post, he found the issue and let us know in the post above yours.
tstrayer
Jan 17, 2012 08:43 AM
kevinjgray
Mar 3, 2011 12:07 AM
1fastsedan
Tuner & Dyno
Jan 12, 2011 11:54 PM
Mr. Uy
Jan 26, 2007 01:16 PM
