bumper off to replace washer pump??
Old Jan 4, 2019 | 11:28 AM
foreste1's Avatar
5 Year Member
I believe I need to replace my sons washer pump on 04 coupe, does anybody know if I can access from just wheel well or does bumper need removed, hoping not.
Old Jan 4, 2019 | 12:02 PM
GaryEvans's Avatar
Maybe the inner fender liner but not the bumper.
Old Jan 4, 2019 | 12:11 PM
foreste1's Avatar
5 Year Member
Ok thank you! I cant seem to find a video with somebody actually replacing it
Old Jan 4, 2019 | 06:43 PM
Obeyxjason's Avatar
G35 coupe 6mt
I had to change my bottle and pump it’s 10x easier with the bumper off or the car securely raised up enough for you to see and change it out, try using old rubber gasket if it’s not to worn. The new ones are a pain to get in
Old Jan 5, 2019 | 11:25 AM
foreste1's Avatar
5 Year Member
Ok thank you, dont really want to get into taking bumper off. Will try inner fender first, crazy they did not make these easily accessible.
Old Jan 5, 2019 | 11:49 AM
FreshLikeAG's Avatar
I just had my passenger fender liner off this morning and you can easily see everything
Old Jan 5, 2019 | 12:16 PM
foreste1's Avatar
5 Year Member
Perfect! That was what I was hoping, did you take the wheel off as well to get inner fender well out by chance? I am thinking of just turning wheel and pulling part of inner fender well out
Old Jan 5, 2019 | 08:45 PM
I took the wheels off to replace both fender liners. Gives you plenty of room and made things simple
Old Jan 6, 2019 | 12:23 AM
Blue Dream's Avatar
I drove ttrank's car solo
Don't try to replace it with the wheel on. Makes the job infinitely harder and it only takes a couple of minutes to jack the car up and remove the wheel.
Old Jan 6, 2019 | 08:52 AM
Either way you will be jacking the car up to take load off the suspension. So unless you like a good challenge, then take the wheel off
Old Jan 6, 2019 | 01:19 PM
foreste1's Avatar
5 Year Member
Thanks everybody, will jack up and remove the wheel. Grabbing pump this week and my new jack will be here shortly from Costco, thanks!!
ZXERT
Mar 5, 2024 02:13 AM
2004MTsedandude
Aug 30, 2013 06:46 PM
lakers714
Apr 22, 2013 11:39 AM
joedaddy1
Feb 29, 2008 01:29 PM
ross6200
May 6, 2007 10:37 PM
