Gear grinds while in 1st gear with clutch pedal out?
Old Apr 29, 2019 | 12:44 AM
Chi An Huynh's Avatar
g35 coupe 6mt brembo
Hi, i just got my first G and i'm having some clutch problems.
When i drive in 1st, it does a grinding noise with the clutch either in or out
It also grinds when switching gears too fast so i've been granny shifting which is no fun.
I was hoping someone could tell me what's potentialy wrong with it, hope it's nothing major
Old Apr 29, 2019 | 10:30 AM
gary c's Avatar
Welcome to the G35 Driver forums! From what you describe, your clutch isn't totally disengaging which might require a new clutch rather than a simple adjustment! Visit a trans shop in your neighborhood you trust or one your friends recommend...not the stealership! Again, welcome and enjoy the ride!
Gary
Old Apr 29, 2019 | 01:51 PM
cswlightning's Avatar
Driving it like that will wear out your syncros in your transmission REALLY fast. It could be something stupid like a clutch pedal adjustment that wasn't done properly after a clutch replacement, but more likely if you just bought the car you've got an actual issue that needs fixing unless the PO was an idiot.
Old Apr 29, 2019 | 01:59 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Bleed the clutch, replace the transmission fluid. If it's still misbehaving then it's time for more troubleshooting, might be a worn clutch master or slave cylinder.
draco1020x
Drivetrain
Mar 24, 2015 06:19 PM
RiversideS13
Feb 5, 2012 11:40 PM
RichardLe187
Feb 11, 2010 10:38 AM
jlo0109
Drivetrain
12
Oct 31, 2007 06:54 PM
Hooman6MT
Sep 19, 2005 04:30 PM
