G35 does not sound or feel the same during idle and driving
Old Apr 30, 2019 | 06:16 PM
johnson_vq's Avatar
I recently changed my valve gasket covers and I did leave the plenum piece with the throttle body out in the open for a couple of days. I was wondering if this might have to do with the throttle body needing to be cleaned or anything else besides that. The car rattles and shakes when I was inside and from the outside the exhaust idle is more jittery. When I went to drive it around it didn't feel the same. Hopefully you guys can help thank you.
Old Apr 30, 2019 | 09:25 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Did you unplug the TB? If so you MUST do all the proper relearns for everything to function properly. It's also a common mistake to accidentally pinch the oil fill neck between the two plenum halves when reassembling everything.
Do all these resets in order.
https://nicoclub.com/archives/g35-35...procedure.html
Andy.
Jul 5, 2017 10:03 AM
GWord256
May 16, 2016 03:28 AM
eagles512
Jul 13, 2010 12:27 PM
djb703
Jan 28, 2009 11:36 PM
IS300TOG35
Dec 4, 2005 01:51 AM
