G35 Oil Leak Help.
Old May 7, 2019 | 11:11 AM
johnson_vq's Avatar
G35 Oil Leak Help.
I've been dealing with an oil leak for my g for awhile however I tried to diagnose what the problems was. I went online to find out where it may be. I changed my oil filter, redid the valve gaksets, checked if there was leaks on the oil pan, checked the o-ring, and checked the hoses. If there are any where else I should check can you guys let me know.
Old May 7, 2019 | 11:18 AM
telcoman's Avatar
Veteran: Army
Are you sure it is engine oil and not transmission, power steering or differential fluid?
Have you ever had the vehicle up on a lift for a thorough inspection by a professional?
Telcoman
Old May 7, 2019 | 12:15 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Step 1: clean up the mess
Step 2: use an inspection mirrors and flight light to watch EXACTLY where it leaks from
Step 3: fix leak
Stop throwing parts at the car hoping something finally works.
Old May 7, 2019 | 01:57 PM
MooseLucifer's Avatar
5 Year Member
blk
Are you finding oil on the ground, or is your oil level dropping on the dip stick? The VQ is notorious for drinking oil. A catch can will help a little, but it's best to get used to checking your oil frequently, especially if you're asking your VQ to "sing in the upper registers" often, so to speak.
Old May 7, 2019 | 04:12 PM
saywat?'s Avatar
so u dont actually see a leak. ?
Old May 7, 2019 | 04:16 PM
johnson_vq's Avatar
I do see oil. I would drive it and come back home and wake up in morning and see drips of oil on the driveway.
Old May 7, 2019 | 04:18 PM
saywat?'s Avatar
yea like telecoman said may not even be engine oil ur seeing.
Old May 7, 2019 | 08:13 PM
johnson_vq's Avatar
Probably. The color is dark and yellowish. I just assumed it was oil but might be something else. And it is dripping in between the transmission and engine.
Old May 7, 2019 | 09:17 PM
cleric670's Avatar
BANNED!!!
That's usually the rear main seal failing at the back end of the crankshaft, it leaks into the bellhousing and then drips out onto the ground.
You can also do a UV dye test and use a black light to find out where it's leaking from.
G35-R
Dec 10, 2014 10:29 AM
g35guy86
Mar 4, 2011 06:00 PM
Ludecrasher
Mar 16, 2008 11:25 PM
Six
Mar 8, 2007 03:56 PM
