Lost key fob: mechanical key only unlocks/locks doors
Old Jul 18, 2019 | 12:14 PM
Druber's Avatar
2007 Infiniti G35 Coupe
Unhappy Lost key fob: mechanical key only unlocks/locks doors
This is my first post so bare with me here,
I recently lost my last key fob for my 2007 Infiniti G35 Coup. The mechanical key will unlock/lock the doors and put the windows up and down if the key is fully twisted and held from the driver's door keyhole. I am under the impression that the mechanical key IS programmed to the car based on the fact that the door locks and windows respond to the mechanical key.
The mechanical key, however, will not twist the ignition switch to start the car. I get a red key light indication on the dash when I attempt to turn the ignition.
I can't start my car in order to take it to the dealership. Even if I order a fob online, I won't be able to program the remote since the car won't turn to the ACC position.
Am I doomed to take my car to the dealership for this repair? Should I order a fob offline first to reduce the price? I'm concerned that this is going to be a ~$500 fix for a key missing key fob. (Factory key fob: 200, towing, ~200, service, ~100).
Thanks for your help,
Druber
Old Jul 18, 2019 | 05:43 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Door lock actuation does not read the transponder, it's a switch on the cylinder you are engaging.
You need your BCM programmed to accept the new key transponder.
Old Jul 18, 2019 | 05:44 PM
cleric670's Avatar
BANNED!!!
Call around to different locksmiths, many have a tool to program the BCM and their service charge is cheaper than the tow to Nissan.
Old Jul 20, 2019 | 10:06 AM
Blue Dream's Avatar
I drove ttrank's car solo
^This. Most locksmiths offer mobile service as well and will come to you.
Old Aug 17, 2019 | 08:30 AM
JamesMichael's Avatar
bmw
Really, so can i hire locksmith hamilton for that key fob issue?
Old Aug 21, 2019 | 05:55 PM
Blue Dream's Avatar
You'd have to call and ask, we can't answer that for you.
Old Aug 22, 2019 | 12:31 PM
RobertDarwin111's Avatar
g35
Yes, you can call whatever
in your area and talk to them about, we don't answer it as said.
Jetranger
May 29, 2021 09:04 PM
chinaBby7126
Nov 4, 2017 02:33 PM
2003G35JDM
Sep 10, 2016 05:53 AM
bpaine2
Feb 9, 2012 12:21 PM
madmike1029
Apr 29, 2009 07:31 PM
