Brake lights not working and VDC Off, ABS, and SLIP lights are on?
Old Aug 11, 2019 | 05:17 PM
cuzin.danny's Avatar
INFINITI G35 Coupe 6MT w/Brembo's
I checked my 10A tail light fuse and it’s perfectly fine. The same night this happened my trunk lid also stopped opening for some reason.
My ABS unit isn’t buzzing like some have reported in the past nor brake fluid being low, or pads/rotors being low.
Anyone got any ideas what this could be?
Much appreciated
Old Aug 11, 2019 | 09:38 PM
I just replaced my brake switch and brake lights still don’t work. So I can rule out:
- blown fuse
- bad brake light switch
Any help at all?
(Trunk lid was a torn wire like last time, but it’s fixed now. )
Old Sep 2, 2020 | 10:43 AM
Piko35de's Avatar
18yo’s daily driving, highway pulling machine that is slow
I’m having the same issue right now, can’t seem to find a blown fuse anywhere either. My trunk wasn’t opening and I come to find 4-5 wires in the grommet from the car to the trunk lid basically cut in half. I soldered them up and the trunk works now but I still can’t figure out why the tail lights don’t turn on and why the vdc, abs, and slip lights are on. Checked all my fluid levels and everything is topped off as should be. Called the dealership and they said it could be the ground in the rear, and don’t think it’s anything else because other symptoms would show. Currently stuck in park on my driveway. Any help is appreciated.
04 5At coupe
Old Sep 2, 2020 | 01:06 PM
Thanks for reminding me about this post. So to give an update, my issue was with those same exact trunk wires. At least four of them were completely torn so I increased the length of the wires and crimped all of them. Haven't had any issues with that since.
Old Feb 8, 2025 | 04:57 PM
BlakeTheGreat's Avatar
Did you ever fix the problem? If so what was it im having the same issue with my car
04 5At coupe
How did you fix your problem? I’m having the same issue right now, I changed the brake light switch along with the cruise control switch under the pedal. Please Help
spikecam23
Jan 26, 2020 12:33 PM
GWizz14
Jan 5, 2018 02:26 PM
Project 04
Apr 21, 2013 11:48 AM
stpdevil
Florida G Club
Feb 25, 2008 04:25 PM
Rickebob
Oct 1, 2007 09:36 AM
