Airbag light flashing + horn doesnt work.
Old Oct 1, 2019 | 01:27 PM
Andy.'s Avatar
Are they related? Problem just started happening a week ago.
2005 Coupe with 179k
No check engine light but I will try to run a code today
Old Oct 1, 2019 | 02:01 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Possibly related since they both go through the clockswitch (spiral cable switch) which is located in the steering wheel. Have someone pull the airbag code and if it is for the driver main airbag then that's likely the culprit.
Be sure to read up on how to properly replace it or you can end up with a steering angle sensor issue.
Duinit
Feb 24, 2024 08:53 PM
hrabini
May 10, 2012 10:13 PM
Goldendragoon
Apr 6, 2011 09:48 AM
AgentAero04
Jan 10, 2008 06:42 PM
god_of_cpu
Nov 10, 2006 10:17 PM
