Rear Diff Bushing Nut STRIPPED!
Old Dec 11, 2019 | 07:17 PM
thenewworldman's Avatar
G35 Coupe 6MT
I didn't take the best angle on this 17mm nut and stripped it.
I got an extractor socket, but it can't get deep enough as the bolt is recessed and the bolt bottoms out.
What should I do?
Can I cut out the bushing, drop the diff and then cut out the inner collar so I can get a better grip on this nut?
Something always has to go wrong when doing upgrades, huh?
I have a new bolt on order from the dealer, I just need to get this thing OFF!
Thanks in advance for any and all input.
17mm nut stripped, extractor socket is too shallow and the head of the bolt hits the 3/8" drive.
Old Dec 11, 2019 | 08:27 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Old Dec 11, 2019 | 09:53 PM
G35 Coupe 6MT
I bought a similar kit today at Harbor Freight, the 17mm slips....
Old Dec 15, 2019 | 12:45 PM
Urbanengineer's Avatar
12 pints and impacts should not be synonymous. 6 points ftw.
Old Dec 15, 2019 | 04:04 PM
GaryEvans's Avatar
I don't see an extractor socket set listed. What is the part number?
Old Dec 15, 2019 | 07:05 PM
cleric670's Avatar
BANNED!!!
The thing about the extractor is you need to put a lot of PRESSURE on it for them to properly bite into the remains of the nut. Make sure you removed the muffler so you can really get up behind and push on the back of the impact wrench really hard while you slowly reverse the thing. It's not about speed, it's about pressure to get it to cut into the existing nut and properly bite it.
Old Dec 15, 2019 | 07:07 PM
cleric670's Avatar
BANNED!!!
The only thing a 12 point socket is good for is adding weight to the garbage can so it doesn't blow away.
Old Dec 16, 2019 | 11:05 PM
srv2nv's Avatar
G35 Sport
Cut through the bushing to remove diff with broken bushing attached. That should give you room to cut the bushing shorter to reach the nut.
Old Dec 17, 2019 | 01:45 PM
Good point ^^^
Old Dec 21, 2019 | 12:07 AM
G35 Coupe 6MT
That is exactly what I did. The extractor socket could never grab the nut due to the bolt. I took it to my local shop and they removed it for me. All is good. The car feels great. It feels like more power reaches the tires, an aluminum shaft is next for sure. I swear it gave me a bit of under steer or in that direction (no pun intended). I am happy with the results and my Greddy X coilovers made by KW should arrive tomorrow.
Merry Christmas y'all!
Old Dec 23, 2019 | 11:04 AM
shurur's Avatar
2003 G35 Coupe
well cheer up..you aren't working on an Audi.
Those nut extractors are the way to go and a must have.
As said, the regular screw type extractors work only so-so, and should only be used where you can get at it and put some pressure down on them, and then only on shallow bolts.
Aside:
Just to make you feel better.
On my Audi 3.0, I had my tensioner bolt shear off at the the block.
A shop said that they would do it.
They drilled into the bolt uncentered and ended up shearing the extractor into the bolt and into the block.
Then declared themselves done with my car.
The block had to be drilled out around the entire bolt to get it out, then I had to progressively drill the mess out, mm by mm, to 14mm.
Then threaded to 16mm and a stainless 16x10mm locksert threaded in.
Mechanics were telling me I would have to throw away the block!!
You can do this.!!
EDIT..dooh..see you got a competent mechanic!
Good for you!
Old Dec 23, 2019 | 11:11 AM
shurur's Avatar
2003 G35 Coupe
Audi loves these damn things..I replace them regularly with hex heads wherever possible
Old Dec 27, 2019 | 11:59 AM
G35 Coupe 6MT
I learned about thread tapping, helicoils, etc. when working on my first Audi!
Aside:
You can do this.!!
Good for you!
ryanm8
Intake & Exhaust
Jan 3, 2012 04:06 PM
OMG35S
May 6, 2011 12:58 AM
XDR-V35
Drivetrain
Jan 2, 2010 02:56 PM
