Sell or Repair
Old Dec 15, 2019 | 09:34 PM
illmat716's Avatar
G35 Coupe
Sell or Repair
What's up guys. First time posting, but this forum has helped me out a lot. Quick Run Down: Purchased a 2005 Infinity G35 Coupe for 3K. Recently replaced my catalytic converters with some Hi-Flow Cats, but started noticing additional issues after my latest inspection with my coupe. Engine problems and suspension problems specifically. Here is the rundown.
MILES ON CAR CURRNETLY: 145,000
ISSUES: STERRING RACK LEAKAGE, FRONT STRUTS LEAKING AND WORN, TIE ROD MOVEMENTS, EXHAUST LEAKING, NEED NEW CONTROL ARMS, BUSHINGS, POSITION RINGS AND TIMING CHAIN going bad
LIST OF REPAIRS:
Engine SWAP with a used solid tuned engine (89K miles) + labor: $1,200
TIRE RODS, CONTROL ARMS and BALL JOINTS replacement parts: 349.00
POWER STEERING LEAK: $260.00
EXHAUST SYSTEM + Labor: $100.00
NEW SHOCKS: $130.00
BRAKES and ROTORS: 160.00
CLOCKSPRING: 62.00
ALL in ALL I am looking at around an additional : $2300 not including labor for some of these repairs.
I was expecting repairs would have to be done on this car, it's a daily driver and beater. Should I just cut my losses and sell it as if or part out. Or should I put more money into it and ride it out for a few more years?
Any realistic and practical advice would be great.
Thanks once again guys!
Old Dec 15, 2019 | 11:16 PM
eazdaskeez's Avatar
Hmmmmm, where did you get the info that your timing chain was going bad? And your piston rings?
Old Dec 16, 2019 | 11:35 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Yeah if they didn't attach the compression test results then it could just be bullshit. I'm also curious about the timing chain since it's usually good for the life of the motor and only needs the tensioner (and occasionally a broken guide) replaced.
Old Dec 16, 2019 | 11:41 AM
eazdaskeez's Avatar
I smell a hint of bull poop
EricF
V36 Brakes, Suspension, Wheels & Tires
Feb 19, 2019 01:07 PM
cuzin.danny
Sep 7, 2018 04:30 PM
Seebass
May 6, 2018 03:56 PM
LI-G35Driver
Dec 15, 2015 07:21 PM
hrdwirk1
Mar 18, 2013 04:32 PM
