Question About brembos on 6mt
Old Mar 8, 2005 | 06:42 PM
aren21's Avatar
Question Question About brembos on 6mt
I am looking for a used 03-04 G35 coupe 6mt. Prices are still high for used ones in LA, around 30 thousand, with 20-40 thousand miles. My question is do all of the 03-04 6mt come with brembos standard or is it an option.
Thank You
Old Mar 8, 2005 | 08:06 PM
Cruz's Avatar
I know it was standard on the 04's...not sure about the 03's though.
Old Mar 8, 2005 | 08:20 PM
aren21's Avatar
Thanks for the info on the 04's. Anyone know if they were standard on the 03's?????????
Old Mar 8, 2005 | 08:22 PM
weaksauce's Avatar
i am 99% certain they are standard on a 6MT for both years...
Old Mar 8, 2005 | 08:23 PM
Techuinang's Avatar
Yes they were. Brembos were only available for 6MT for 03 and 04, not for AT.
Old Mar 8, 2005 | 09:37 PM
GZire's Avatar
Definitely standard for all manual transmission 04's and like the others pretty sure it was the same case for the 03's.
Old Mar 8, 2005 | 10:37 PM
gspotter's Avatar
You can't tell on the '05's from the outside now that a G Coupe is a 6MT or not.
Old Mar 8, 2005 | 10:49 PM
G35Vision's Avatar
Yes you can tell .. The smile seems to be a bit bigger
Old Mar 8, 2005 | 11:08 PM
EricIsKlumzyee's Avatar
19" rims standard are on 6MT.. and yes the smile is bigger
Old Mar 9, 2005 | 06:11 AM
g35sammy's Avatar
brembos suk major a$$! i have this HORRRRRRID squealing noise that pops up when i pretty much run my car a little hard......and it only stops if i brake.....and i can't replicate it for the damn dealerships......can ANYONE tell me what this is!???? im guessing it has to do with me running her a bit hard.....i do 1/4 racing every now and then....
Old Mar 9, 2005 | 07:12 AM
tekknikal's Avatar
i had this same problem.
replacing my brake pads solved it.
i switched to hawk street pads (same as nismo), but i would bet that replacing the oem pads would work just as well.
i think it is caused by the back plate of the pads being improperly made, causing the wear indicator to prematurely touch the rotor.
edit: see here for more info:
https://g35driver.com/forums/g35-coupe-v35-2003-07/26303-squeaking-problem-need-opinions-advice.html
i hope that helps you
Old Mar 9, 2005 | 07:39 AM
Speedoholic's Avatar
G (enie) FUNK ERA
Standard on 03-04 coupes, N/A for sedans.
Old Mar 9, 2005 | 08:09 AM
g35sammy's Avatar
https://g35driver.com/forums/showthread.php?t=26303
thanks man~ but i think my problem is a little differen't. i hear it when im just "crusing"......i mean i don't hear it when i apply the brakes at all you know? oh well.....freakin G is gettting me upset! -.-
Old Mar 9, 2005 | 08:19 AM
tekknikal's Avatar
re-read my post in the other thread. the symptoms of your problem look like the same as mine. i dont know if it affects you when you turn, thats how mine was.. .eventually i was hearing it when driving straight and cruising. (point 8 - which eventually got worse to the point of driving straight) if i held the brakes i did NOT hear it. (point 7)
good luck
Old Mar 9, 2005 | 08:34 AM
g35sammy's Avatar
it's early~ so could you just tell me if the dealership fixed the problem for freE? was it covered since i mean the problem SHOULD NOT be happening right? thanks for your help Tek!
