cant get cruise control or horn to work
Old Feb 8, 2020 | 01:07 PM
larsen1921's Avatar
coupe
Hey guys, quick question. I have tried everything and my horn no longer works and neither does my cruise control. I can't find the relays or fuses that are specific for. Can neš tell me? What the hell to do
Old Feb 8, 2020 | 01:48 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Test the horn relay by using your key fob to lock the doors, it should also chirp the horn (or for fun you can press the panic button!). If the horn IS WORKING with the alarm then your problem is likely the clock spring.
Since you also lost cruise control I'm guessing it's the clock spring.
If it still doesn't work then the horn relay is plugged into the fusible link, there are only two relays, horn and back up lights and they are the same relay so you can swap them to test for a bad relay.
Wiring schematic is section WW - Wiper, Washer, Horn in the FSM.
https://www.nicoclub.com/archives/in...e-manuals.html
KulG35
Aug 29, 2007 05:52 PM
UltimateGee27
Mar 27, 2007 06:47 PM
ARTofDESIGN
Jul 7, 2006 09:38 PM
GLykos
Apr 11, 2004 11:20 PM
GLykos
